Stuff and Things.
Re: Stuff and Things.
Here's a quick photo of the 1772 DFS board and the new sideways Ram/Rom board which I've just fitted and will give a good test shortly.
PhilC wrote: Thu Nov 28, 2024 1:48 pm Here's a quick photo of the 1772 DFS board and the new sideways Ram/Rom board which I've just fitted and will give a good test shortly.
Niiiice:)
Just arrived today:
So I can take a look tonight at the disk drive upgrade :)
I also got a set of terminator pliers and terminals, time to make some of my wiring neater :)
Post by HigashiJun »
I was about to get a Beeb Master 128 last month, but my conscience just told me 'No'.
:cry:
HigashiJun wrote: Thu Nov 28, 2024 10:27 pm I was about to get a Beeb Master 128 last month, but my conscience just told me 'No'.
:cry:
I see a lot of Master ideas in the Archie, probably best to stay away :)
rubber_jonnie wrote: Thu Nov 28, 2024 11:32 pm I see a lot of Master ideas in the Archie, probably best to stay away :)
A wise advice.
8-)
Higgy
Post by Higgy »
@HigashiJun I suppose the Master 128 and X68000 share the same 'need a working battery' otherwise your messing with CMOS/SRAM settings every time you turn it on.
Oh, and their PSU's are guaranteed to need initial work done on them :lol:
Higgy wrote: Fri Nov 29, 2024 12:32 pm @HigashiJun I suppose the Master 128 and X68000 share the same 'need a working battery' otherwise your messing with CMOS/SRAM settings every time you turn it on.
Yes to both of those statements.
It's been a busy day for post, also just arrived:
I pre-ordered this in September and just arrived now :)
chronicthehedgehog
Post by chronicthehedgehog »
It's a comfortable pad although I had to put a shim under the DPAD pillar to reduce annoying multi-presses
I'm using a hacked version of the recent wired CX78+ as my 'daily driver' with my ST.
chronicthehedgehog wrote: Fri Nov 29, 2024 3:34 pm It's a comfortable pad although I had to put a shim under the DPAD pillar to reduce annoying multi-presses
I have a wired new one and also an original and I have to say that the new models are very close to the old for sure. I think the CX78 is overall one of my favourite controllers, but I do have a 7800 for which they were a specific controller.
I think the CX78+, wired or wireless, is a bit stiffer in the joypad area than the original, but I expect over time it'll loosen up.
