Floppy connector un-f*ck pcb
Thanks to Icky for unravelling this connector chaos..I have started in a new un-f*ck PCB... Highlighted below are just the GND connections to illustrate the changes which matched the image provided by Icky.
I have checked all the other pins and all seemed to be swapped out correctly...
What seems to have happened is my connector pinout was actually correct..
But electrically what I had labelled as pin one for example, was actually pin three electrically in the schematic. :roll:
Problem being while I labelled up the correct pins in the PCB part, and the correct pins in the schematic part and labelled up correctly, there was a third connection for electrically connecting the pins between schematic and PCB part,which I must have forgot to do (again) :( I really wish there was a better editor in Eagle. One where everything is just on one screen rather than flicking around all sorts of screens and boxes to make all the connections :roll:
As before, I will post the PCB file here (Hopefully later today) so anyone who wants to order them can do so.
Re: Floppy connector un-f*ck pcb
DOWNLOAD
floppy_UF.zip
I would suggest people order from OSH ($8.20 for 3 boards) Particularly people USA direction (or outside of EU). Of course anyone in the world can order these, it will be a lot quicker and cheaper than waiting for boards to arrive to me and then having to ship them out.
https://oshpark.com
Job for today is to fit this puppy to the STF board
:bravo:
This is not an easy one to fix up. Holes aren't normal spacing so you cant use the header spacers to stabilise
How I did the monitor one was to push one pin through from the motherboard, then into the unf*ck board, then solder on and repeat one at a time, obviously starting at the back row.
Remember to space it nicely so Its easier for me to make your spacer, :P
Forgottenmyname wrote: 24 Oct 2018 18:40 How I did the monitor one was to push one pin through from the motherboard, then into the unf*ck board, then solder on and repeat one at a time, obviously starting at the back row.
Yeah - this is the way I am doing it but the holes are wider too so everything is wobbling about with my shaky hands.
Clamps in abundance :)
No hope of me ever doing it then, lol.
The Floppy Un-f*ck board works and now we have symmetrical boards on the STF :)
https://www.exxosforum.co.uk/forum/viewt ... 209#p12209
I found some more of these boards If anyone still needs them...
