Raven060 (luciodra build).
luciodra
Re: Raven060 (luciodra build).
Post by luciodra »
agranlund wrote: 13 Nov 2024 19:52 Nice. That looks like it booted all the way to the desktop.
I have stability problems perhaps because the 060 doesn't have a fan but only a heatsink. If I put the 512 MB Fat16 formatted CF into the CF-ide adapter the system doesn't boot...maybe it should be formatted in a format more compatible with Atari?
Finally, after Raven has been running for a while I have video disturbances as if from radio interference...
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
PicoGUS 2.0
agranlund
Post by agranlund »
luciodra wrote: 13 Nov 2024 20:25 If I put the 512 MB Fat16 formatted CF into the CF-ide adapter the system doesn't boot...maybe it should be formatted in a format more compatible with Atari?
It should be just a normal MS-DOS FAT16 partition, nothing Atari specific needed.
I used Linux gparted to set up the different partitions on my current card.
I've also had good result with "diskpart" on Windows following a guide like this:
https://vmspot.com/format-fat16-usb/
But even if the partition was not recognised I would have thought it should boot to emuTOS anyway.
I have two FAT16 partitions which are available in EmuTOS, both are 255mb.
And then also one pretty large FAT32 partition plus an even larger EXT2FS which EmuTOS cannot understand but MiNT can.
With the card attached, do you get any output in the log at all running the debug rom?
Perhaps double check that pin1 of the adapter lines up with pin1 on the motherboard and they're not getting flipped the wrong way around or something. That could for sure make it not boot at all (I know from experience :) )
If you have master/slave/cable-select jumpers on the adapter then perhaps try those too.
It should be said that I have only tried with the two CF cards I have so the possibility for compatibility issues with other brands/models cannot be completely dismissed too.
Still. Very cool to see the progress of it now getting to the desktop!
luciodra
Post by luciodra »
agranlund wrote: 13 Nov 2024 22:29
RAVEN060
CPU:  M68LC060R04
ROM:  20241111
RAM0: 01000000
RAM1: 01000000
RAM2: 01000000
InitBss
InitHeap
InitUart
InitIkbd
InitMfp
InitMidi
InitI2C
InitRtc
InitCfg
InitVbr
InitMonitor
InitAtari
InitVbr
InitMmu
InitEmu
InitTos
Start
bios_init()
processor_init()
Address Bus width is 32-bit
vecs_init()
init_delay()
init_delay loopcount_1_msec=110000
machine_detect()
ttram_detect()
ttram_detect(): ramtop=0x03900000
detect_ide(): has_ide = 0x01
detected_busses = 0x0004
VGA card detected at IO=0xfedc0000 / mem=0xfec00000
machine_init()
bmem_init()
Memory map before balloc() adjustments:
        _text = 0x00e00000
       _etext = 0x00e7be10
        _data = 0x00e7be10
       _edata = 0x00e7be10
         _bss = 0x00002140
   _endvdibss = 0x0000a9f0
        _ebss = 0x00012e14
       stkbot = 0x00000800
       stktop = 0x00001000
_end_os_stram = 0x00012e14
       membot = 0x00012e14
       memtop = 0x00400000
cookie_init()
fill_cookie_jar()
cookie_vdo = 0xffffffff
cookie_mch = 0xffffffff
cookie_snd = 0x00000001
wrong nvram: expected=0xff00 actual=0x0000
cookie_akp = 0x00000000
cookie_idt = 0x0000002f
font_init()
mfp_init()
screen_init_mode()
linea_init()
linea_init(): 640x400 1-plane (v_lin_wr=80)
screen_init_address()
before balloc_stram: membot=0x00012e14, memtop=0x00400000
balloc_stram(32768, 1)
balloc_stram(32768, 1) returns 0x003f8000
 after balloc_stram: membot=0x00012e14, memtop=0x003f8000
v_bas_ad = 0x003f8000, vram_size = 32768
setphys(0x003f8000)
vt52_init()
after vt52_init()
init_system_timer()
Panic: Exception number 21
sr=2000 pc=00e011e0
D0-3: 00002700 00000000 0058148c 00000000
D4-7: ffffffef 00400000 00000000 00000001
A0-3: 00000114 00000050 40001b4a 00e0912a
A4-7: 20008180 20000020 00000ffc 00000f74
 USP: fffff1ff
 d0: 00000000  d2: 00e011e0  d4: 00e00daf  d6: 00e00d8a
 d1: 003f0000  d3: 00e00d09  d5: 00e00d98  d7: 00e00d76
 a0: 00e0936d  a2: 00e08230  a4: 00e0910c  a6: 00000ffc
 a1: 00000050  a3: 00e08230  a5: 20000020  a7: 0000231c
 pc: 00e0824e  sr: 2004                   usp: fffff1ff
vbr: 00581000  tc: 00008210 srp: 00580e00 urp: 00580e00
dt0: 00000000 dt1: 00000000 it0: 00000000 it1: 00000000
pcr: 04310403 bcr: 00000000 ccr: a0808000
I think there is some other problem... ;)
ET4000AX 1Mb T0
PicoGUS 2.0
agranlund
Post by agranlund »
luciodra wrote: 13 Nov 2024 23:17 I think there is some other problem... ;)
The data line used for talking to the MFP is shared with 8 bits of the dataline of the IDE interface.
You're crashing on a gibberish interrupt number returned by the MFP so IDE is most likely interfering on the bus when it shouldn't.
My best guesses would be:
- U402 (Iksi) handles the control signals for the IDE port so it could be something to look at. Perhaps it's signalling IDE-enable all the time even when it's not supposed to be addressed.
These are all through-hole components so risk of soldering mistakes are quite limited though. Programming error perhaps?
I guess you might gain some info by testing if you crash the same if you have adapter connected but no CF card in adapter. I'm not sure that would make anything conclusive but interesting none the less.
- Perhaps the adapter is just bogus. Not unheard of if it's an ebay one.
- Or, something with the the port <-> cable <-> adapter setup is not correct for some reason so pin1 on motherboard is not pin1 on device then that would probably guarantee exactly this to happen.
luciodra
Post by luciodra »
This is the adapter I bought. I could have damaged it because I also inserted it in the wrong direction. The error gives me both with CF and without CF inserted.
Today I will do other tests...
ET4000AX 1Mb T0
PicoGUS 2.0
luciodra
Post by luciodra »
I'm doing some tests and with the adapter inserted without CF it boots correctly, while with the CF inserted (I tried three different ones) it freezes at the beginning and doesn't even give a debug line.
ET4000AX 1Mb T0
PicoGUS 2.0
agranlund
Post by agranlund »
I don't know where pin1 is on the adapter, but if it's one of the red ones then the adapter at least has the correct pinout for the connector type (female).
If the adapter would have had a male connector then the correct pin1 location should instead be one of the blue ones.
Normally, motherboard and device both have male pins with exactly the same pinout.
That fact makes them impossible to directly connect, even if you physically change the connector on one -- pin1 of motherboard would go to pin2 on device if you did. The IDC cable between is what makes it work.
If you have a device with a female connector, and it's designed to plug directly into a motherboard, then it should have cable-pinout rather than device-pinout. Disk-on-modules do exactly this, and I assume most/all(?) adapters would too.
But it's all too easy to imagine these almost-free ones possibly reusing exactly the same everything as the more usual male variants, then just swap the connector and call it a day.
I'e encountered one of those before so maybe I'm just jaded and untrusting, and possibly had bad luck :)
Out of curiosity I grabbed one from my box-of-stuff just now and it has the correct cable-pinout, it even had a key'ed connector with pin20 blocked which was surprisingly professional (though not great for me since the male header I use on Raven has all pins even the key one... I should probably find a different part number)
I apologise this felt a bit long and overexplaining. My point was mostly that I personally wouldn't drop that female adapter from the suspect list until I had verified that it is indeed using the pinout you'd expect for your intended purpose.
If it turns out all fine and correct then I would maybe looks at Iksi related stuff since it's part of controlling some of the IDE signals.
luciodra
Post by luciodra »
Ok, a damaged pin in the cf-ide adapter could be the cause of the problem. I'll try another one and see...
ET4000AX 1Mb T0
PicoGUS 2.0
luciodra
Post by luciodra »
Unfortunately it is not the CF-ide adapter
ET4000AX 1Mb T0
PicoGUS 2.0
luciodra
Post by luciodra »
Small update: with the 40 GB IDE hard disk of my Mac Mini, formatted MSDOS, Raven now boots, only I don't see any disk. The hard disk motor can be heard...
| std free  (1 entries) = 0x0000048e {
|   0x00048e[0x013664,0x3e499c],
| std alloc (0 entries) = 0x00000000 {
| alt free  (1 entries) = 0x00004008 {
|   0x004008[0x1005d6c,0x28fa294],
| alt alloc (11 entries) = 0x00003ff6 {
|   0x003ff6[0x1004d6c,0x001000], 0x003fe4[0x1004a7c,0x0002f0],
|   0x003fc6[0x1002ea4,0x001bd8], 0x003fb4[0x1002b24,0x000380],
|   0x003fa2[0x1002a24,0x000100], 0x003f84[0x1002a18,0x00000c],
|   0x003f72[0x1000218,0x002800], 0x003f60[0x1000118,0x000100],
|   0x003f42[0x100010c,0x00000c], 0x003f30[0x100000c,0x000100],
|   0x003f1e[0x1000000,0x00000c],
===/mem_dump==========================
BDOS returns: 0x01004d6c
BDOS (fn=0x0044)
BDOS: Mxalloc(2048,0x0003)
BDOS ffit: mp=&pmdalt
BDOS ffit: requested=2048
xmgetmd(): got new MDBLOCK at 0x00004022
xmgetmd(): got MD at 0x00004026
BDOS ffit: start=0x01005d6c, length=2048
BDOS Mxalloc: returns 0x01005d6c
===mem_dump==========================
| alt free  (1 entries) = 0x00004026 {
|   0x004026[0x100656c,0x28f9a94],
| alt alloc (12 entries) = 0x00004008 {
|   0x004008[0x1005d6c,0x000800], 0x003ff6[0x1004d6c,0x001000],
|   0x003fe4[0x1004a7c,0x0002f0], 0x003fc6[0x1002ea4,0x001bd8],
|   0x003fb4[0x1002b24,0x000380], 0x003fa2[0x1002a24,0x000100],
|   0x003f84[0x1002a18,0x00000c], 0x003f72[0x1000218,0x002800],
|   0x003f60[0x1000118,0x000100], 0x003f42[0x100010c,0x00000c],
|   0x003f30[0x100000c,0x000100], 0x003f1e[0x1000000,0x00000c],
BDOS returns: 0x01005d6c
BDOS (fn=0x004e)
findit(A:\EMUICON.RSC)
 dcrack(0x00006cfe -> 'A:\EMUICON.RSC')ckdrv(0)
blkdev_getbpb(0)
device is invalid
BDOS returns: 0xffffffde
can't load user desktop icon file A:\EMUICON.RSC
BDOS (fn=0x0044)
BDOS: Mxalloc(2320,0x0003)
BDOS ffit: requested=2320
xmgetmd(): got MD at 0x00004038
BDOS ffit: start=0x0100656c, length=2320
BDOS Mxalloc: returns 0x0100656c
| alt free  (1 entries) = 0x00004038 {
|   0x004038[0x1006e7c,0x28f9184],
| alt alloc (13 entries) = 0x00004026 {
|   0x004026[0x100656c,0x000910], 0x004008[0x1005d6c,0x000800],
BDOS returns: 0x0100656c
BDOS (fn=0x0044)
BDOS: Mxalloc(4192,0x0003)
BDOS ffit: requested=4192
xmgetmd(): got MD at 0x0000404a
xmgetmd(): MDBLOCK at 0x00004022 is now full
xmgetmd(): removed MDBLOCK at 0x00004022 from mdb chain
BDOS ffit: start=0x01006e7c, length=4192
BDOS Mxalloc: returns 0x01006e7c
| alt free  (1 entries) = 0x0000404a {
|   0x00404a[0x1007edc,0x28f8124],
| alt alloc (14 entries) = 0x00004038 {
|   0x004038[0x1006e7c,0x001060], 0x004026[0x100656c,0x000910],
BDOS returns: 0x01006e7c
disp() to "        "
BDOS (fn=0x003d)
findit(A:\EMUDESK.INF)
 dcrack(0x00006d1c -> 'A:\EMUDESK.INF')ckdrv(0)
blkdev_getbpb(0)
device is invalid
xopen(A:\EMUDESK.INF,0): rc=-33
BDOS returns: 0xffffffdf
BDOS (fn=0x0019)
BDOS returns: 0x00000000
BDOS (fn=0x000e)
BDOS (fn=0x0049)
BDOS: Mfree(0x01006e7c)
BDOS Mfree: mpb=pmdalt
BDOS freeit: mp=&pmdalt
BDOS freeit: start=0x01006e7c, length=4192
xmfremd(): MD at 0x0000404a freed
xmfremd(): MDBLOCK at 0x00004022 now has free entry, moved to mdb chain
disp() to "        "
BDOS (fn=0x0044)
BDOS: Mxalloc(-1,0x0003)
BDOS ffit: mp=&pmd
BDOS ffit: requested=-1
BDOS ffit: maxval=4082076
BDOS ffit: maxval=42963332
BDOS Mxalloc: returns 0x028f9184
BDOS returns: 0x028f9184
BDOS (fn=0x0044)
BDOS: Mxalloc(36416,0x0003)
BDOS ffit: requested=36416
BDOS ffit: start=0x01006e7c, length=36416
|   0x00404a[0x100fcbc,0x28f0344],
|   0x004038[0x1006e7c,0x008e40], 0x004026[0x100656c,0x000910],
obj_init(): allocated 569 screen objects
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
BDOS (fn=0x0044)
BDOS: Mxalloc(2394,0x0003)
BDOS ffit: requested=2394
xmgetmd(): got new MDBLOCK at 0x00004064
xmgetmd(): got MD at 0x00004068
BDOS ffit: start=0x0100fcbc, length=2396
BDOS Mxalloc: returns 0x0100fcbc
| alt free  (1 entries) = 0x00004068 {
|   0x004068[0x1010618,0x28ef9e8],
| alt alloc (15 entries) = 0x0000404a {
|   0x00404a[0x100fcbc,0x00095c], 0x004038[0x1006e7c,0x008e40],
BDOS returns: 0x0100fcbc
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "        "
disp() to "SCRENMGR"
disp() to "EMUDESK "
disp() to "        "
AES: EMUDESK: evnt_multi()
disp() to "        "
ET4000AX 1Mb T0
PicoGUS 2.0
Return to “RAVEN 060 - USER BUILDS”
