68000 PLCC bent pins/contact issues
Pacman
Post by Pacman »
I've got contact problems with one or multiple pins of my STe's 68000 (U100) PLCC socket.
My first thought is to use a continuity tester (multimeter) between say pin 1 of the CPU and pin 1 of the socket.
Unfortunately there's not enough space to keep the probes apart (I've even tried using two needles attached to crocodile-clips), so what else can I try?
Also, what's the correct/best way to bend a PLCC bend back the way it should be?
STe | MonSTer with dual IDE-CF memory card adapter | NEC Multisync 1990SXi | ST_ESSC | RSVE | Link '97 | Sony HD floppy drive/AJAX controller | Exxos HD floppy module | Battery-backed Ricoh realtime clock module | Discovery cartridge | C-Lab Unitor-2 | C-Lab Export | C-Lab Combiner | C-Lab Steady Eye | C-Lab Human Touch | Unicorn USB
💧Are you a good person? 💧Living Waters
Re: 68000 PLCC bent pins/contact issues
Have a look here: Adjusting PLCC contacts
Pacman
Post by Pacman »
Exactly what I was looking for!
Thank you :thumbup:
Users browsing this forum: ClaudeBot, DuckAssistBot and 4 guests
