Posts: 4347 Joined: 03 Sep 2017 10:57
Post
by Icky » 22 Oct 2018 23:44
exxos wrote: 22 Oct 2018 23:40
Icky wrote: 22 Oct 2018 23:34
Nope its booted - The 16MHz needed to be buffered so I took it from the 16MHZ_BUFFERED_1 that was spare on IC900 pin 12
oh sweet! benchmark time then ;)
Spoke to soon its temperamental. Went to put in the HDD and it did not boot. No signal this time.
Put it back to 8MHz and its working again.
Posts: 28211 Joined: 16 Aug 2017 23:19
Post
by exxos » 22 Oct 2018 23:48
Icky wrote: 22 Oct 2018 23:44
Assume you going through a 33R resistor to the DMA clock pin ?
Post
by Icky » 23 Oct 2018 00:00
exxos wrote: 22 Oct 2018 23:48
You assume right :)
It does seem to be temperamental on 16MHz
Post
by exxos » 23 Oct 2018 00:04
Icky wrote: 23 Oct 2018 00:00
Could be interfacing issues to the MMU, or the DMA might not just cope with it. Up the voltage a bit, see if it helps :P
Post
by Icky » 23 Oct 2018 00:10
exxos wrote: 23 Oct 2018 00:04
Will take a better look tomorrow.
Post
by Icky » 23 Oct 2018 18:55
Icky wrote: 23 Oct 2018 00:10
Yep got it stable with a bit more juice :)
However although its running at 16MHz the Gigafile is not recognised @ 16MHz. Drop back down to 8MHz and it sees it
Post
by exxos » 23 Oct 2018 19:07
Icky wrote: 23 Oct 2018 18:55
Does the floppy still work ?
Post
by Icky » 23 Oct 2018 19:11
exxos wrote: 23 Oct 2018 19:07
Yes the floppy works fine.
EDIT: @16MHz
Post
by exxos » 23 Oct 2018 19:13
Icky wrote: 23 Oct 2018 19:11
EDIT: @16MHz
If you can format a floppy fully, it will test the DMA out at the higher speeds better...
Assume gigafile doesn't like the faster port speed :(
Post
by Icky » 23 Oct 2018 19:21
exxos wrote: 23 Oct 2018 19:13
I'll give that a go shortly - need food first :)
Users browsing this forum: CCBot and 2 guests
