I've been Coleco'd
Re: I've been Coleco'd
HigashiJun wrote: 30 Sep 2024 11:38 @rubber_jonnie
Ouch, quite hot for 4116 RAM...
Better to fit heatsinks or maybe replace them with 4164 RAM for reliability ?
That's not unusual for 4116 TBH, it's the dead one that is cold that bothers me more :)
Post by HigashiJun »
rubber_jonnie wrote: 30 Sep 2024 11:57 That's not unusual for 4116 TBH, it's the dead one that is cold that bothers me more :)
The cold one is definitely dead.
HigashiJun wrote: 30 Sep 2024 12:03
Definitely dead:
I was going to say that's VRAM problem.
Yes, replace then with hacked 4164 chips and you will probably not need the -5V or +12V.
stephen_usher wrote: 30 Sep 2024 12:25 Yes, replace then with hacked 4164 chips and you will probably not need the -5V or +12V.
A wise advice !
stephen_usher wrote: 30 Sep 2024 12:25 I was going to say that's VRAM problem.
Indeed, I'm about to hack a 4164 :)
I did have some 4116's but I think I used them in the last Spectrum I resurrected, so the 4164 is my only option.
I'm just going to replace the dead one for now though.
OK, so RAM hack done:
And things are looking much better:
So I think next I'll have a look at if I can get a composite signal out of this thing.
No need to solder pin 1 of a 4164 as it's not connected, so just cut it off. :-)
You should be able to get RGB out of it with a daughter board which fits underneath the TMS VDP chip. https://videogameperfection.com/product ... -v2-board/
Seems my excitement was short lived...
Looks like another RAM IC has died. No huge surprise, just not 100% sure I have enough RAM to replace it all.
stephen_usher wrote: 30 Sep 2024 13:39 No need to solder pin 1 of a 4164 as it's not connected, so just cut it off. :-)
I have sometimes used 41256's so it's a habit I have of soldering it to GND. Also, I don't like cutting pins off good IC's :)
BTW I have seen the RGB out mods but I don't have any RGB displays, so I usually use composite out via a Retrotink to HDMI.
Users browsing this forum: apple [bot], Bing [Bot], ClaudeBot, OAI-Search [Bot], petal [bot] and 7 guests
