TFMSX rev 2 features & problems
Home for the Terriblefire MSX clone
Re: TFMSX rev 2 features & problems
Oldskool wrote: 22 Sep 2024 16:42
terriblefire wrote: 22 Sep 2024 16:17 I've had feedback that this has fixed the issue. I suppose i should do a 2b version of the board.
As far as understand it from the Discord discussen the status is that the fmpak now works. The memory mapper does however not seem to work so always 64kb.
You can test the ram with ram check tools. It will show 512Kb. But MSX2 will only ever show 128K on the boot screen.
Use this tool: - https://www.msx.org/forum/msx-talk/software/testram-v20
Oldskool
Post by Oldskool »
terriblefire wrote: 22 Sep 2024 16:43
Yes could be in practice there is 64kb. So it seems there is still something not fully ok with the memory mapper although the fm now works. So for arcade cabinet use a big plus for other computing usage still some optimization seems to be needed on the memory side of things.
this is how the ram is mapped....
although i believe it's moved to slot3 now
Oldskool
Post by Oldskool »
terriblefire wrote: 22 Sep 2024 16:57 this is how the ram is mapped....
It seems to have 64kb and the memory mapper does not seem to work.
At least this is the status @ Jeroen now and was also part of the issue I had. It was the fmpac and this.
Additional memory needs to come from external cartridge and so on…,
Oldskool wrote: 22 Sep 2024 17:22
Yes i can confirm this. I have a regression. It seems to be related to things i did while developing the MSX2 Mapper Cart. Shouldnt take long to sort.
Sent a new FW to Jerone let's see what the result is.
Oldskool
Post by Oldskool »
It’s fixed😀😀😀😀👍👍👍
One more fix was sent over. When this is verified i'll post 2 firmwares here. One for those with the WAIT fix done, one for those without it.
NYYRIKKI
Post by NYYRIKKI »
Hey, it seems that things are moving forward while I look away. That is great!
First of all, I'm very happy to hear that the memory mapper issue is finally fixed as Chuck suggested I need to change the faulty CPLD chip to get around the 64kB issue (I did not ever get to it) and now this sounds 100x more easy to fix!
... also cool that you managed to tweak the FM-PAC to work. I was under the impression that it was due to lack of +12v and -12v as the FM-PAC worked great when connecting to slot expander that had it's own PSU, but now it sounds like such monster setup might not be needed anymore... Very, very nice!
Keep up the good work!
Oldskool
Post by Oldskool »
The FMPac mentioned is via a Picomsx.
https://www.msx.org/wiki/Jeroen_Taverne_MSX_Pico
So emulated…
Return to “TFMSX”
