TFMSX rev 2 features & problems
Home for the Terriblefire MSX clone
Oldskool
Re: TFMSX rev 2 features & problems
Post by Oldskool »
Tried the firmware which is posted on page 1.
This maps stuff differently indeed.
But still no FM music and the memory issue seems comparable.
Now mapped 64kb on slot 3 vs 2 with original firmware. The other 64kb is mapped at the slot were the mem expansion is but this mem is gone then…. And the other mem is not seen by this testrom.. Is there maybe an updated firmware? I could not find it on the tf github.
Tinyslot as rom file booted from pico MSX menu:
Oldskool
Post by Oldskool »
Will send the tfmsx to the pico msx guy.
He will probably find the issue…
ok thanks. if there is a change needed my side i can do it.
i'm pretty sure that if there were sound output you would hear it. maybe a clash
Oldskool
Post by Oldskool »
@terriblefire
Tfmsx is now at Jeroen he was wondering if he could potentially have a look at the source code if he found issues. Not sure what is handy. Maybe he could contact you directly somehow for discussing this. I can imagine that you also don’t want some strange guy fiddling with your code…
His preferred email is:
msxpico@gmail.com
I've dropped an email. i can for sure give the pertinent equations to him.
Right think i have spotted the issue.
CPLD always outputs high or low and thus the Cart cannot assert /WAIT. Its an easy fw fix but unfortunately i think its missing a pull up to let the CPLD go high impedance. We might need to graft on a pull up resistor.
Oldskool
Post by Oldskool »
Could you send the updated experimental Jed file to Jeroen? Including the resistor mod?
Oldskool wrote: 21 Sep 2024 13:42 Could you send the updated experimental Jed file to Jeroen? Including the resistor mod?
experimental jed here..
Resistor mod is just a resistor between 500R and 1K between Wait and VCC on the Z80
tfmsxr2_top_exp.jed.zip
I've had feedback that this has fixed the issue. I suppose i should do a 2b version of the board.
Oldskool
Post by Oldskool »
terriblefire wrote: 22 Sep 2024 16:17 I've had feedback that this has fixed the issue. I suppose i should do a 2b version of the board.
As far as understand it from the Discord discussion the status is that the fmpac now works. The memory mapper does however not seem to work so always 64kb.
But the great news is that we can play Aleste with FM..
Return to “TFMSX”
Users browsing this forum: ClaudeBot and 65 guests
