It's best to rotate before uploading TBH but I'll see if I can get them sorted for you. 3-6? Can you let me know how they need to be rotated.HigashiJun wrote: 17 Sep 2024 11:26 @tOriman
Thanks !
@rubber_jonnie
Thanks ! The break was good but as always too short... 8-)
BTW, any chance to have the pictures placed correctly ?
Sharp X68000 XVI inbound (tomorrow...)
Re: Sharp X68000 XVI inbound (tomorrow...)
That's what I always do before uploading an image, but it's sometimes upside-down once the image uploaded.rubber_jonnie wrote: 17 Sep 2024 12:12 It's best to rotate before uploading TBH but I'll see if I can get them sorted for you. 3-6? Can you let me know how they need to be rotated.
And this time, the rotate function didn't work too.
It would be great if you could rotate images 3 to 6 at 90° anticlockwise.
Many thanks !
Pictures should be sorted, let me know if not what you were expecting.HigashiJun wrote: 18 Sep 2024 05:52That's what I always do before uploading an image, but it's sometimes upside-down once the image uploaded.rubber_jonnie wrote: 17 Sep 2024 12:12 It's best to rotate before uploading TBH but I'll see if I can get them sorted for you. 3-6? Can you let me know how they need to be rotated.
Many thanks !
@rubber_jonnie
:thanksyellow:
:dualthumbup:
:thanksyellow:
:dualthumbup:
You're welcome.
Played a bit with the Henkan Bancho and hard drives images this morning, and it's what I got.
Boot screen at start-up from HDD:
Parodius:
Akumajo Dracula:
As you can see, the screen is not centered most of the time but some games allow a perfectly centered screen.
Tinkered the monitor settings but nothing changed... :(
I guess I will have to get another monitor for my X680000 sooner or later.
Parodius:
Akumajo Dracula:
Higgy
Nice.
You need to update your HD image, there is a better v2.20 one on nfgames forum 8-) .
Regarding monitor there is a little trick which might help:
Load Switch.x and change background colour from Black to say Purple. Your monitor then should detect the edges of the X68000 output and hopefully centralise better. Once done you should be able to change background back to black. But if you press 'Auto' on your monitor you will have to do it again.
@Higgy
Yes, I have the v2.20 image but I didn't try it yet.
The one I was playing with is the 68030 one.
Didn't know the monitor trick. I will try it ASAP. Thanks !
I plan to buy a SHARP CZ-606D but I think a Mitsubishi DiamondStar would be a better and cheaper solution...
Higgy
For the 2.20 image pretty sure there is a command line option for if you have a 030 (maybe FPU also?). There is also a nice 030 X68K logo you can have at boot.
Lovely graphics on these machines, nice work so far, hope you sort the screen centering easily.
Users browsing this forum: apple [bot], ClaudeBot, gpt [bot] and 21 guests
