DFB1X issues with Master of Orion [Falcon030] [1oom]
DharkStar
Post by DharkStar »
Hi,
i bought and installed a DFB1X in my Atari Falcon and it`s running fine. I also got a lot of games to run in Alt-RAM with PRG Flags and i can see an increase in speed, but I'm not able to get Master of Orion [Falcon030] [1oom] to work via DFB1X Alt-RAM.
Game is running in normal 16 MHz mode with 14 MB ST-RAM, but very slow. When i enable "Run in Alt-RAM" in the executable program with PRG Flags and try to run the game, i get two bombs and it`s not working. I tried all variations with PRG FLAGS, but i`m not able to get it to work.
Does anyone have an idea what`s to do to get the game running via DFB1X Alt-RAM, because i want to try the game in accelerated mode?
Has anyone else tried this?
Thanks!
DharkStar
viking272
Re: DFB1X issues with Master of Orion [Falcon030] [1oom]
Post by viking272 »
The original discussion was over here:
https://www.atari-forum.com/viewtopic.p ... on#p404083
Potentially the author of the SDL conversion may see it?
DharkStar
Post by DharkStar »
Thanks for your answer!
Yes, i know the discussion about this topic in atari-forum, but i thought i post it here related to DFB1X. Maybe someone has already had the same experience. But I think I'll ask this question there too.
smoore100
Post by smoore100 »
I can try this out tonight over the weekend, where did you get the game from so I'm looking at the same version?
Many thanks,
Simon
DharkStar
Post by DharkStar »
Thank you, that would be very helpful!
I used the version available at Atarimania. See the following link:
https://www.atarimania.com/game-atari-s ... 36491.html
Please keep in mind, that you need the LBX files from the original game. In this case, please also take a look at the instructions at Atarimania.
Additional info: Game is running in normal mode with 16 MHz and 14 MB ST-Ram, but without sound (that`s another problem, but it`s not so important from my point of view).
I'm very excited about your findings. Thanks!
smoore100
Post by smoore100 »
Ah, I don’t own the game unfortunately
viking272
Post by viking272 »
smoore100 wrote: 07 Sep 2024 11:01 Ah, I don’t own the game unfortunately
Isn’t the game free and then you find the data files elsewhere? Like doom and it’s WAD files, they’re ‘out there’?
smoore100
Post by smoore100 »
Yep, I found them.
After a very quick test running under TOS 4.04 it works no matter what is set in PRGFLAGS and can't see any difference in performance.
DharkStar
Post by DharkStar »
Thank you for your tests!
That`s interesting, because when i enable "Run in TT-RAM" with PRG Flags i get bombs and the program crashes. On my environment it only runs in "normal mode", when i disable all options with PRG Flags or when only "Fastload" is activated, but then as far as i understand it, it runs only in normal 16 MHz Mode and with ST-RAM. With all other settings the program crashes, when using Alt-RAM.
But thanks anyway!
If someone can provide me a complete package of the executable game I'll give it a try when the Falcon's next on the bench and see if I can find any problems.
A ZIP/RAR of a working directory is ideal. I'm afraid I don't have the time to go hunting for files I don't understand, apologies.
