A500 plus black screen
Steve_w
Re: A500 plus black screen
its an A500+ rev 8.
BERR is always high at 4.96v
- Admin sponsor
What about HALT?
I missed that it was a Plus... Battery damage?
The bus transceivers are right in the firing line of the battery, so I would suspect them for a start... But that shouldn't stop the ROM from working as that's directly on the main address and data bus.
I think that you said that you checked continuity between the ROM address lines and data lines to the CPU, but I'd check them again. Also to GARY.
Does /ROMEN on GARY go low and is it seen to go low on the ROM as well?
Steve_w
HALT is high
Steve_w
There has been battery damage, I've socketed and replaced the data path logic chips and repaired broken traces.stephen_usher wrote: 14 Aug 2024 13:55 I missed that it was a Plus... Battery damage?
I'm wondering if there is an intermittent problem, maybe around GARY as probing ROMEN on power on I could see activity for about 3 seconds then nothing. Subsequently on power up ROMEN is now just high with no activity.
Have you replaced the Gary socket? Commodore single wipe sockets seem very unreliable.
Steve_w
No, I had removed it and repaired corrosion to traces, but put the dual wipe socket back.stephen_usher wrote: 14 Aug 2024 17:09 Have you replaced the Gary socket? Commodore single wipe sockets seem very unreliable.
As the issue looks a bit intermittent (I have seen some activity briefly) I'm tending to think it might be an issue like a socket and Gary deals with these initial control signals, so have removed it from the board and will replace with a new one.
- Admin sponsor
IMHO its not worth trying to fix a battery damaged A500+. Transplant everything over to an ReA500 or A500++.
I know people disagree but it will be a never ending rabbit hole of repairs and you can never be sure all the acid is neutralised.
Steve_w
Hi,
I like to try and save them where I can, I have repaired nearly 30 boards, this one is proving to be a bit of trouble though. There was some low level corrosion, but that has been cleaned, tinned, tested and UV solder mask applied.
I replaced the socket with a brand new one, the issue still persists.
I'd like is possible to try and hunt down the issue with help from people here as I think its a great learning experience, I lack knowledge of the order of signals firing and what generates the signals. It may not be a simple as this but if I start at the beginning and work through logically I should be able to come to a positive outcome.
Steps with Diagrom installed
1. reset signals applied, driven from RESET circuit.
2. ?? does CPU then try and so things using /AS, UDS, LDS, etc ??
3. ROM code read, serial output works (assuming a working 1488 IC), OVL set
4. Screen colours then indicate issue, or diagrom indicates RAM issues with horizontal bars.
I think once step 3 is achieved it gets a bit easier to troubleshoot using diagrom, just need to get there.
The sequence is:
By the way, you should read the thread about the Falcon with a black screen... Some of the last tests with the ROM removed may be useful for your diagnosis too.
- Reset goes high.
- CPU then does four read cycles of 16 bit words starting at address 0x0 and incrementing the address each time.
- CPU uses this information to read the first instruction from the address read from the first four reads and begin execution.
- Put the address on the address bus.
- Set R/W to read.
- Lower /AS (Address Strobe) to tell the system that there's a valid address on the address bus.
- Wait for /DTACK (DaTa ACKnowledge) to go low, telling the CPU that the data on the bus is ready.
- Read the data from the data bus.
- Raise /AS.
- Wait for /DTACK to go back up.
