Exxos,exxos wrote: Tue Aug 06, 2024 4:21 pmThe Videl chip also controls the RAM.sdisla wrote: Tue Aug 06, 2024 4:13 pm Question for you, a bad VIDEL chip can cause the system to halt? I thought that is just not video but at least able to initialize.
The diagnostic cartridge only needs the system to be somewhat alive, mostly CPU being able to run with ROM.
The floppy drive does not light or flicker dimly at all.
So, in this case I guess is to keep looking for anything related to solder joins.
Also, I check the 5 volts on the RAM which are there.
Anything else I can check on the VIDEL chip to ensure that is not working properly?
I check pins 14,44 & 73 ext clk is there also 25 & 32 MhZ
Thank you,
