Not yet, but it will.
agranlund
DrZiplok
It seems possible that this is a terminal program / TinyUSB flow control interaction problem; there are some discussions about some of these in the TinyUSB issues on github (and honestly there aren't too many other options)...agranlund wrote: 28 Jul 2024 17:29 The more probable explanation is that the programmer software is not compatible with some terminal programs.
Oldskool
Almost done and ready for some testing.
Just was cleaned by a friend in an ultrasonic pcb cleaner.
Now a couple of days drying.
agranlund
Wow! Nice!Oldskool wrote: 30 Jul 2024 22:10 Almost done and ready for some testing.
I'd love to have access to one of those ultrasonic cleaners. cleaning up flux residue is among my least favourite things :)
Once you get to actually launch EmuTOS, you absolutely need 060SP.PRG first, or at least very early, in your AUTO folder.
The sourcecode is here: https://github.com/freemint/freemint/tr ... arch/060sp
But there are no pre-built binaries of it so I placed one here:
https://github.com/agranlund/raven/tree/main/sw/support
This should probably be built into Ravens EmuTOS since it's necessary for the 060 to be properly backwards compatible.
peters
Would 060SP.PRG be any use on other 060 machines ?
agranlund
I assume they all have the Motorola support code baked into their respective TOS already?
Else you'd crash whenever it tries to execute one the instructions they removed from hardware, both integer and floating point ones.
ct60's have a modified TOS which already includes the functionality of 060SP.PRG, I gather.
agranlund
Fun toys from Serdaco!
McFly Red Terror Edition:
Gloriously lo-fi and very very bad... I like it!!
It goes well together with my two red soundcards and it even has a red LED on the bottom side when powered on. What more could one wish for :lol:
Dreamblaster X2GS:
Holy crap does this one sound good! I'm amazed.
This will be the main one installed in the computer.
I had that small Dreamblaster S2 since before and I really think it's great sounding and solid option too.
Dreamblaster X2GS:
peters
I'm waiting for mine. I have no idea if it will work.
Oldskool
Tried it today for the the first time.
So programmed Nessi this worked.
Narnia gets a bit hot.
As I don’t have the correct serial cable I’m not able to see serial output (I thought I had one but it was the male version).
Don’t see any output from the et4k yet or is there no support in this rom version for the et4k and is always a driver needed.
Cf is plugged in with 060 program in the auto folder.
Users browsing this forum: ClaudeBot, danboid, dml, elterwater, Mikerochip, Steve and 3 guests
