exxos finally in the game!
Re: exxos finally in the game!
Good idea with the video board, I removed all of the black plastic spacers when I did mine.
Forgottenmyname wrote: Thu Oct 18, 2018 6:08 pm Good idea with the video board, I removed all of the black plastic spacers when I did mine.
Snap - I did to and then it made it more difficult to line the pins up when putting the video board into the main board.
Exxos - while you have the soldering iron out might want to desolder the XTAL and put in a socket so you can replace with other XTALs
Icky wrote: Thu Oct 18, 2018 6:34 pm Snap - I did to and then it made it more difficult to line the pins up when putting the video board into the main board.
Yep! :lol:
Icky wrote: Thu Oct 18, 2018 6:34 pm Exxos - while you have the soldering iron out might want to desolder the XTAL and put in a socket so you can replace with other XTALs
Yeah, I need to take this out anyway as the assembly company did not solder that resistor which half goes under it..
16MHz fix done.
GLUE PATCH DONE
(Forgot to take a image of the long wine which goes to the DMA 's resistor pack)
You are on fire tonight Exxos. You’ll have this patched before the days end at this rate
sandord
Post by sandord »
exxos wrote: Thu Oct 18, 2018 7:57 pm GLUE PATCH DONE
You're ticking off @troed just like that?
sandord wrote: Thu Oct 18, 2018 8:18 pm You're ticking off @troed just like that?
I think troed is away on business for the next couple of weeks.
Icky wrote: Thu Oct 18, 2018 8:15 pm You are on fire tonight Exxos. You’ll have this patched before the days end at this rate
Yeah, burnt my finger :P
MFP RESISTOR FIX
Some chips and connectors now on...
Return to “ALPHA USER BUILDS”
