Booster clock switching + DMA nerding
Re: Booster clock switching + DMA nerding
Post by JezC »
Badwolf wrote: 26 Jul 2024 16:26
JezC wrote: 26 Jul 2024 11:29 @Badwolf I'll be interested to know if/when you think you have a final solution/version to test...
I think I do now, but it requires some physical modifications which I need to document. A new revision is probably on the cards.
If you're happy to cut a few traces and wire in a few bodges, then I'd be keen to get additional feedback.
Yes, I'll probably finish the original build & briefly test it & then do the mods once know it's basically working.
No rush, just update us when you can! Thanks.
JezC wrote: 26 Jul 2024 21:45
If you've not yet put on the socket strip and the pin headers, it's easier to cut the traces.
Basically you need to:
* Cut BG to BG on the headers (tiny trace between DIP64 pins 11.
* Cut the VCC line going to the CKE pin on the SDRAM (the short 45 degree trace to a via coming out of pin 37 on the RAM chip)
* Run a bodge wire from the BG line going to the motherboard to TP4
* Run a bodge wire from the BG line going to the CPU to TP5
* Run a bodge wire to the CKE pin on the SDRAM chip to TP3
Here's how I did it:
TP1 remains the TOS 2 decoder.
I've a plan for TP2, but probably only @coonsgm would be interested in that...
coonsgm
Post by coonsgm »
What is this I would be interested in??? TP2 you say...
agranlund
Post by agranlund »
coonsgm wrote: 27 Jul 2024 16:18 What is this I would be interested in??? TP2 you say...
TurboPower2 ? :)
coonsgm
Post by coonsgm »
agranlund wrote: 28 Jul 2024 14:13
TurboPower2 ? :)
Well then, I am 100% for more power. Turbopower is just that much better.
Post by JezC »
@Badwolf I'll dig out the board & check if I'd soldered the socket/headers on or not...been so long I honestly can't remember!
:roll: :?
coonsgm wrote: 28 Jul 2024 19:07
agranlund wrote: 28 Jul 2024 14:13 TurboPower2 ? :)
Haha.
No, TP2 is Test Point 2. DSTB has five test points and four have now been co-opted by other functions, but TP2 appeared available.
I had it in my mind that you talked about measuring the effectiveness of accelerators on games in one of your videos -- or perhaps it was in a forum post. Anyway, one of my old dev boards pulsed a line when a write was made to the video shifter registers. Implication being that a double-buffering switch was occurring. I thought I may add that to TP2 on DSTB1 by default.
With a suitable frequency counter, it lets you measure the instantaneous FPS of any double-buffered game. Just set up a vaguely stable and repeatable section of play and note the frame rate. Try again with the booster.
8MHz STRAM:
16MHz ALTRAM:
8MHz STRAM:
16MHz STRAM (game doesn't support running in AltRAM):
We can therefore conclude Stunt Car Racer isn't really CPU limited and is memory limited instead. It would need a patch to let AltRAM kick in, or a MSTE-style cache to get much boost.
Frontier, OTOH, because it supports AltRAM (by accident -- hard coded frame buffer addresses), gains a healthy boost.
coonsgm
Post by coonsgm »
This is an awesome way to technically measure the performance goodness and better understand where the bottleneck is in the system.
