I. Can't. Believe. My. Eyes!
I ordered this package on monday and today (thursday) it's already here (The Netherlands)! Now I'm sure the postage company has upgraded their boats to hovercrafts :D
And there it is!
I still have to do the following things before I can start:
- order parts
- desolder stuff from my donor ST
- take a deep breath
I'm really excited though! :yay2:
Sandord - progress
sandord
Sandord - progress
TheNameOfTheGame
Re: Sandord - progress
That was fast! Congrats on getting your project going! :dualthumbup:
sandord
My current theory is that the wind must have been blowing eastward during transit really hard.
PaulJ
Yes, I can second that! The wind definitely blows eastward, and in France the wind is @ hurricane levels! The wind is so bad in France I've quit ordering from there. Even though the winds in GB blow eastward there not that intense.sandord wrote: 18 Oct 2018 17:04My current theory is that the wind must have been blowing eastward during transit really hard.
sandord
I'm using my Silly Style STF (C070523-001 REV.D) for parts, since it has really bad video anyway (and I fried the ROMS a while ago :lol:).
sandord
Desoldering is HARD.
I'm practicing by removing passive components first. So far I desoldered:
- 13 pin DIN monitor connector
- DB19 ACSI Port
- Reset switch
- DMA Socket
I'm worried about the moment when I have to start desoldering chips. If I look at how long I have to heat a lead before all the solder is sucked into the wick, I'm afraid I'll fry the chips. Then, the remake won't run and I'll probably spend ages before I figure out there's a broken chip causing it.
- DB19 ACSI Port
- Reset switch
- DMA Socket
I used a desolder pump to suck the solder away from each chip leg and hole when removing from my donor board. The pump I used has a silicone nozzle so you can put it right over the iron, leg and hole making a seal to get as much out as possible.sandord wrote: 20 Oct 2018 19:00 Desoldering is HARD.
- DB19 ACSI Port
- Reset switch
- DMA Socket
Unfortunately looks like its more than doubled in price from when I got mine - https://www.amazon.co.uk/gp/product/B002MJMXD4
sandord
That's what I started out with. Altough I think my pump is of rather bad quality, I think. The first 10 legs or so of the DMA socket worked perfectly, and then suddenly... nothing. I mean, only small amounts of solder would be sucked, not the entirity of it. I cleaned the sucker, didn't help. I had exectly the same problem a year or two ago with another sucker.Icky wrote: 20 Oct 2018 19:08 I used a desolder pump to suck the solder away from each chip leg and hole when removing from my donor board. The pump I used has a silicone nozzle so you can put it right over the iron, leg and hole making a seal to get as much out as possible.
I think I'm going to try to press the sucker nozzle more firmly against the lead, perhaps that'll help.
Sometimes desolder pumps get gunked up.sandord wrote: 20 Oct 2018 19:16 That's what I started out with. Altough I think my pump is of rather bad quality, I think. The first 10 legs or so of the DMA socket worked perfectly, and then suddenly... nothing. I mean, only small amounts of solder would be sucked, not the entirity of it. I cleaned the sucker, didn't help. I had exectly the same problem a year or two ago with another sucker.
Open it up by unscrewing the bottom nozzle and the top part where the button is as well. Careful as the spring will push out.
Clean it all out and put some oil round the o-ring seal of the pump part inside. It should then get its suck back :D
You can check the solder sucker by putting it on your finger and then activating it. You should feel the suction.
Typically I've found that the o ring on the front is a weak point and its likely here that you are losing suction. Obviously the plunger has to be clean and in good condition as well.
Users browsing this forum: ClaudeBot and 216 guests
