How is the blitter not causing an unholy mess if it's enabled yet you've nothing in the auto folder to correct its operation with TT-RAM?
Have you a ROM patch? Is that the issue?
:shrug: Oddly it doesn't always cause a total mess, no idea why. But I have done that many tests and I've not really been paying much attention to the blitter stuff..Badwolf wrote: 15 Jul 2024 10:46 How is the blitter not causing an unholy mess if it's enabled yet you've nothing in the auto folder to correct its operation with TT-RAM?
Its my build of TOS206.Have you a ROM patch? Is that the issue?
Certainly an option I guess.stephen_usher wrote: 15 Jul 2024 11:51 Just a random thought... The CPLD isn't trying to supply current on a line which should be open collector is it? That could both be causing the CPLD to heat up more and the voltage be pulled down.
Possibly though I don't really want to "ship" something with some odd issue like that.If a cold spray helps the CPLD, maybe a heatsink?
That's not a good sign. You probably want 'slow' for the most part to reducing ringing.exxos wrote: 15 Jul 2024 11:30 Some tests:
Changing the timings to "slow" makes it lock up sooner. Noticeably during hard drive booting.
I just tried slow again with my firmware tweak and it is also still working fine..Badwolf wrote: 15 Jul 2024 12:49 That's not a good sign. You probably want 'slow' for the most part to reducing ringing.
Scope the BR line? Too many DMAish things involved in the descriptions not to try to rule that out first.
50MHz PAL Mega ST+TF536 (TTRAM): ~2440 frames [coonsgm].
50MHz PAL H5[STF]+TF536 (TTRAM): ~2700 frames [davec].
50MHz PAL STFM+ST536(Exxos) (TTRAM): ~2940 frames [elethiomel].
50MHz PAL H5 + TF536-ST: ~2930 frames [exxos].Users browsing this forum: ClaudeBot and 3 guests
