I am happy with it as it is though. The improvement is vast already.
Of course I'll be interested in future improvements.
Hissing and whistling in the STe audio output
sandord
Re: Hissing and whistling in the STe audio output
I think one of the next steps I suggested was a while ago in this thread, basically start by changing all the electrolytic caps in the DAC circuit to ceramic versions. Electrolytics cause hiss in audio circuits, don't know why, but bet they are not helping. Possible they are more suseptable to RF noise generated mostly by the PSU and RAM aceses etc.
sandord
Oh no, more capacitor browsing :shock:exxos wrote: 14 Oct 2018 01:27 I think one of the next steps I suggested was a while ago in this thread, basically start by changing all the electrolytic caps in the DAC circuit to ceramic versions. Electrolytics cause hiss in audio circuits, don't know why, but bet they are not helping. Possible they are more suseptable to RF noise generated mostly by the PSU and RAM aceses etc.
Seriously, that sounds like an interesting thing to do. Will cause headaches due to the caps being axial, I think though...
Welcome to my world ;)
Yeah, though you may find some which physically fit by the pin pitch.. You probably don't need the full value either.. Looks like there is 47uF for the coupling caps, so even 1uF may work... There are some larger SMT caps like 2220 size which can go up to 100uF.. bodge some wires on those... actually as it looks like I will have to send you a new simm, I have some 33uF ones coming for my PSUs, so I could just send you 4 of those caps as well to try.sandord wrote: 14 Oct 2018 01:35 Seriously, that sounds like an interesting thing to do. Will cause headaches due to the caps being axial, I think though...
It would help if you could scope out the audio path from start to end, and see if any section has the 2600hz spike more than another section...
sandord
Ah, another learning journey awaits ;-)exxos wrote: 14 Oct 2018 11:45 Yeah, though you may find some which physically fit by the pin pitch.. You probably don't need the full value either.. Looks like there is 47uF for the coupling caps, so even 1uF may work... There are some larger SMT caps like 2220 size which can go up to 100uF.. bodge some wires on those... actually as it looks like I will have to send you a new simm, I have some 33uF ones coming for my PSUs, so I could just send you 4 of those caps as well to try.
Let's do it. I mean, the scoping part and trying those caps to see if they help. The other stuff, bodging wires etc. is still a little beyond me, in terms of coming up with stuff like that.
If you can scope before and after the cap changes, then we have all the info documented then. The noise may only be on one section, or all, or get amplified across sections.. nobody knows yet.sandord wrote: 14 Oct 2018 11:57 Ah, another learning journey awaits ;-)
There is a negative -5V rail there somewhere.. noise could even be on that rail.
sandord
I can't get the scope to display the typical 2600 Hz spike. I'm afraid my scope isn't very useful in this regard (no scale display) OR my knowledge of electronics is simply lacking.exxos wrote: 14 Oct 2018 12:02 If you can scope before and after the cap changes, then we have all the info documented then. The noise may only be on one section, or all, or get amplified across sections.. nobody knows yet.
I forgot about this again, need to send you some caps..
can you try with your audio software and measure the points I highlighted in this post https://www.exxosforum.co.uk/forum/viewt ... t=40#p5634
sandord
I just did some measurements. Your picture shows circles around two-sided components so I still had to pick a side. You can see which exact points I measured in the picture below. The read arrows point to the exact points. I hope I got them right :)exxos wrote: 20 Oct 2018 18:45 can you try with your audio software and measure the points I highlighted in this post https://www.exxosforum.co.uk/forum/viewt ... t=40#p5634
sandord
By the way, I used the cinch ground when measuring.sandord wrote: 20 Oct 2018 19:49 I just did some measurements. Your picture shows circles around two-sided components so I still had to pick a side. You can see which exact points I measured in the picture below. The read arrows point to the exact points. I hope I got them right :)
Users browsing this forum: ClaudeBot, Majestic-12 [Bot] and 4 guests
