Exxos STE RAM Upgrade - machine sees only 2 mb
sandord
Post by sandord »
I got my STE RAM upgrade from Exxos store. It consists of 4 SIMM boards.
I installed it but my STE says it's got only 2 MB instead of four.
I did clean the SIMM pins with 97% alcohol. I couldn't really clean the sockets though as there were no IPA wipes included (contrary to what the store says) and my cotton buds don't fit into the sockets. I uses canned air to blow any loose dirt or residue out of the sockets.
Is this a typical thing, the machine ignoring half of the RAM due to bad connections or could there be something else going on?
sandord
Re: Exxos STE RAM Upgrade - machine sees only 2 mb
Post by sandord »
I tried just 2 SIMMS in slot 1+3 and that worked the same way as with 4 SIMMS: 2 MB.
Just 2 SIMMS in slot 2+4 got me flashing vertical bars and no boot. I'm not sure if that configuration is supposed to normally work though.
Oh, I forgot to mention that the TOS 2.06 boot screen takes quite a long time before it starts the memory test (11 seconds). Is that normal?
When you say working in slot 1&3, have you tried both pairs that way ?
Normally its either older Simms damaging the sockets, or can be if to heavy handed with my Simms you can bend them and break them.
sandord
Post by sandord »
exxos wrote: 14 Oct 2018 02:40 When you say working in slot 1&3, have you tried both pairs that way ?
I've just narrowed it down to a single SIMM. I can put 2 of the other 3 SIMMS in an arbitrary combination into slot 1 and 3 and it'll work just fine.
If I put this specific SIMM in any slot, it won't work. Either the screen goes weird or half of the RAM isn't detected if a configuration of 4 SIMMS is used.
Odd :( can you return the suspect simm to me so I can take a look at it ?
sandord
Post by sandord »
exxos wrote: 14 Oct 2018 10:53 Odd :( can you return the suspect simm to me so I can take a look at it ?
Sure. I couldn't find anything mentioning return policy or RMA so how does this work?
sandord wrote: 14 Oct 2018 11:07 Sure. I couldn't find anything mentioning return policy or RMA so how does this work?
I will PM my address to send.
sandord
Post by sandord »
I got a replacement SIMM from Exxos yesterday and the STE is running fine with 4 mb now.
I forgot to say I looked at your returned one. It looks like the solder has "ripped" on one end of the simm.. the boards are a bit fragile (bendy) so that can happen if not careful when inserting them.
sandord
Post by sandord »
exxos wrote: 19 Oct 2018 22:08 I forgot to say I looked at your returned one. It looks like the solder has "ripped" on one end of the simm.. the boards are a bit fragile (bendy) so that can happen if not careful when inserting them.
I've been as careful as possible because I constantly kept thinking about not shattering the slots which I suspect to have become brittle over time.
But I can't say for sure I didn't do something wrong of course.
