The STorm-ST boards need TOS v2.06, EmuTOS or MagiC to work, adding 8 additional megs of ST RAM:
https://wiki.newtosworld.de/index.php?title=Storm_ST
Suska board
Darklord
Re: Suska board
Cyprian
Re: Suska board
If I remember correctly even TOS 1.x supports more than 4MB RAM. It checks available ST-RAM also above 4MB. Therefore if you have ALT-RAM that starts just above ST-RAM ( $400000 ) needs to be disconnected during memory check.exxos wrote: 19 May 2024 21:51Yes indeed, but normally that is alt-ram whch is bolted onto the 68000 and needs PRG flags set. But what I am talking about is, pure ST RAM. In that would TOS itself see more than 4MB if it was installed..Cyprian wrote: 19 May 2024 21:26 There is 'Maddalt' function: https://freemint.github.io/tos.hyp/en/g ... ml#Maddalt
" »Inform GEMDOS of alternative memory« - Register 'Alternative' RAM with GEMDOS. "
It is used to add more than 4 RAM to the TOS memory pool and it was implemented in GEMDOS 0.19 (TOS 2.x)
Thinking about it, you normally have to boot the system without alt-ram enabled because TOS would try and allocate video RAM in alt-ram which results in a black screen. So then Maddalt is used to allocate the RAM and the shifter still gets limited to 4MB. It is a bit messy.. But this to me basically insinuates that TOS does actually check for more than 4MB STRAM.
http://260ste.atari.org
Re: Suska board
It's not ST ram... its alt-ram. over 4MB ST RAM isn't possible due to hardware limits. Only the Falcon that I know of has true 14 MB STRAM.Darklord wrote: 19 May 2024 22:32 The STorm-ST boards need TOS v2.06, EmuTOS or MagiC to work, adding 8 additional megs of ST RAM:
Re: Suska board
Yes that is what I also believe. And what I am asking.Cyprian wrote: 19 May 2024 22:34 If I remember correctly even TOS 1.x supports more than 4MB RAM. It checks available ST-RAM also above 4MB.
Yes that's precisely the problem I ran into that if you do not do this, the video RAM tries to be allocated in alt-ram which he does not have access to.Therefore if you have ALT-RAM that starts just above ST-RAM ( $400000 ) needs to be disconnected during memory check.
Mostly I'm trying to find out what version of TOS supports more than 4MB STRAM. Though I think even TOS104 must support it.
Darklord
Re: Suska board
Ah, saw that (now). Thanks for the correction.exxos wrote: 19 May 2024 22:35 It's not ST ram... its alt-ram. over 4MB ST RAM isn't possible due to hardware limits. Only the Falcon that I know of has true 14 MB STRAM.
Cyprian
Re: Suska board
do you plan to extend ST-RAM size beyond 4MB?exxos wrote: 19 May 2024 22:37 Mostly I'm trying to find out what version of TOS supports more than 4MB STRAM. Though I think even TOS104 must support it.
Re: Suska board
Yes.
Cyprian
Re: Suska board
nice
MMU and SHIFTER in FPGA?
Re: Suska board
Re: Suska board
This looks like the memory test loop, but it seems to default to 4MB. It would imply to me that is that is all it tests to, though I don't understand assembly well enough to really figure out what this loop is doing.
#if (TOSVERSION < 0x300) | TP_50
/* First we try to configure the memory controller */
clr.w d6
move.b #$a,(memconf).w /* default: setup controller for 2Mb/2Mb */
movea.w #$8,a0
lea $200008,a1 /* + 2Mb */
clr.w d0
chkpatloop: move.w d0,(a0)+ /* fill 512-8 bytes with a test pattern */
move.w d0,(a1)+
add.w #$fa54,d0
cmpa.w #$200,a0
bne.s chkpatloop
move.b #90,(v_bas_l).w /* wrote low byte of video address */
tst.b (v_bas_m).w /* touch the middle byte (this should reset the low byte) */
move.b (v_bas_l).w,d0
cmp.b #90,d0 /* low byte not reset? */
bne.s chkmem1
clr.b (v_bas_l).w /* try a different low byte value */
tst.w (palette).w /* touch the color palette */
tst.b (v_bas_l).w /* low byte changed? */
bne.s chkmem1
move.l #$40000,d7 /* 256Kb offset */
bra.s chkmem1b
chkmem1: move.l #$200,d7 /* 512 byte offset */
chkmem1b: move.l #$200000,d1 /* 2Mb = maximum size per bank */
chkmemloop: lsr.w #2,d6 /* shift memory configuration down by a bank (bank 1 is in bits 0..1, bank 0 is in bits 2..3) */
movea.l d7,a0 /* + 512/256Kb bytes */
addq.l #8,a0
lea chkmem3(pc),a4
bra memchk0
chkmem3: beq.s chkmem7 /* bank is not working => */
movea.l d7,a0
adda.l d7,a0 /* + 1024/512Kb byte */
addq.l #8,a0
lea chkmem4(pc),a4
bra memchk0
chkmem4: beq.s chkmem6 /* bank has 512Kb of memory => */
movea.w #8,a0 /* + 0 bytes */
lea chkmem5(pc),a4
bra memchk0
chkmem5: bne.s chkmem7 /* bank is empty => */
addq.w #4,d6 /* 4+4 = 1000 2Mb bank size */
chkmem6: addq.w #4,d6 /* 4 = 0100 512Kb bank size */
chkmem7: sub.l #$200000,d1 /* - 2Mb */
beq.s chkmemloop
move.b d6,(memconf).w /* set memory configuration */
#else
domemchk:Who is online
Users browsing this forum: ClaudeBot, gpt [bot], OAI-Search [Bot], peters and 10 guests
