Hey all,
Started a new post about the 4MB EXXOS RAM upgrade that I recently had issues installing (and getting working with the 1MB/4MB switch) as this is a new issue..
I decided just to heed general advice and not worry about the 1MB/4MB switch, soldered the link on the RAM upgrade board for 4MB and all was good. Until today.
Today the STFM was switched on and I get a light blue screen with thick vertical black bars:
The PSU in the STFM was recapped about 8 months ago - and all voltages tested today are good.
I've checked the install of the RAM board (which has been working fine for a couple of weeks now with constant use) and that's all good too.
I've taken out both PLCC chips, checked and cleaned the sockets and the chip pins and reinstalled them.. I've taken the shifter out and re-seated it too.
Can anyone point me in the right direction on what to check out next?
Thanks,
kbjunkie.
Exxos 4MB Ram Upgrade for C070789 - Different Issue
kbjunkie
kbjunkie
Re: Exxos 4MB Ram Upgrade for C070789 - Different Issue
A quick update...
I noticed that one of the 3 68R resistors that need fitted wasn't soldered properly and was hanging loose at one side. I've completely removed it and fitted another. Also checked for shorts and all is good.
Now all I get is a white screen and no boot. Tried with my Gotek - nothing and even fitted a floppy drive back in and neither will even attempt to boot. Leaving it for a while with no disk and it still doesn't boot into the desktop..
That bad resistor contact was a probable cause of your odd switch issues. But now you seem to have another problem.
You need the diagnostic cart to find out what the problem may be. But it sounds like if bad soldering is in the mix, I think your machine needs professional diagnostics and repair now.
kbjunkie
Been involved in electronics for 30+ years - my soldering is good :-) I've checked all the traces across the desoldered ram chips and your new board for breaks/shorts and all is good there too.
The resistor was not soldered properly as I soldered it in place once the machine was partially re-built as I'd forgotten to do it - so it was tacked temporarily across the pads.
The diagnostic card I have was one purchased from yourself exxos - and I've never really had much luck getting it to work. Cleaning the edge connector with IPA doesn't help and it will frequently just not work. I'll give it another go I guess.
I may build a cart and put the diagnostics on it once more and carry on.
The bad resistor wasn't the issue with the switch. I replaced the resistors after all that mucking around with the RAM board. :-)
Is there anything else that could be causing a white screen with this RAM board?
kbjunkie
kbjunkie
But if you remember I suggested there was some floating signal as the fault with the switch made no sense. So indeed you did have a floating signal, and was likely the cause of your switch troubles. Just having your hand near a IC can alter its state when a signal is floating.The bad resistor wasn't the issue with the switch. I replaced the resistors after all that mucking around with the RAM board. :-)
White screen can have multiple causes, such has bad contents on the GLUE / ROM, bad reset circuit / switch. I think you have gone from installing a RAM board to troubleshooting your whole machine now.kbjunkie wrote: 15 May 2024 09:15 Is there anything else that could be causing a white screen with this RAM board?
With a white screen that's often due to ROM issues, I'd suggest that by pulling and cleaning the PLCC chips you now have a bad contact either on the GLUE or MMU and the ROM can't be accessed.
I'd suggest you pull both and tweak the socket pins and also spray with something like Electrolube or Deoxit before reassembly. It's really easy to upset these sockets.
Generally I have noted that with a white screen the diag carts don't work, but you could try to get a serial cable hooked up to a PC with a terminal program like Teraterm and see if it gives any diagnostics over serial.
kbjunkie
I replaced the resistor after I had decided to give up on the switch. The original resistors were in the board - I measured them out of circuit and one of them was low, so I cut it out and tacked a new 1% 68R resistor in place - but after the issues I had with the switch.But if you remember I suggested there was some floating signal as the fault with the switch made no sense. So indeed you did have a floating signal, and was likely the cause of your switch troubles. Just having your hand near a IC can alter its state when a signal is floating.
I wonder if it is an issue with the TOS ROMS or the GLUE then. I may just bite the bullet and replace the sockets since I have a few spares here. I'll take the advice and check the reset circuit too.White screen can have multiple causes, such has bad contents on the GLUE / ROM, bad reset circuit / switch. I think you have gone from installing a RAM board to troubleshooting your whole machine now.
kbjunkie
I've done that already - pulled the chips, cleaned the pins of the chips and the socket and added a little Deoxit - no joy.With a white screen that's often due to ROM issues, I'd suggest that by pulling and cleaning the PLCC chips you now have a bad contact either on the GLUE or MMU and the ROM can't be accessed. I'd suggest you pull both and tweak the socket pins and also spray with something like Electrolube or Deoxit before reassembly. It's really easy to upset these sockets.
That's a good idea - I'd forgotten about the serial output - I may try that but I reckon that my diagnostic cart has met it's maker. I may just build one :-)Generally I have noted that with a white screen the diag carts don't work, but you could try to get a serial cable hooked up to a PC with a terminal program like Teraterm and see if it gives any diagnostics over serial.
With regards to the cartridge port, I've found the best way of cleaning it is to fold an A4 sheet of paper three times (or four... basically trying to make it the same thickness as the cartridge PCB) and spray it with contact cleaner and then gently insert the corner into the slot and rub in and out. You will have to do this along the whole slot and not rub side-to-side as this can bend the contacts.
The slightly rough surface of the paper will gently polish the surface of the contacts, removing corrosion, but not erode the metal.
But have you tweaked the socket pins as well as cleaning them?kbjunkie wrote: 15 May 2024 10:59I've done that already - pulled the chips, cleaned the pins of the chips and the socket and added a little Deoxit - no joy.With a white screen that's often due to ROM issues, I'd suggest that by pulling and cleaning the PLCC chips you now have a bad contact either on the GLUE or MMU and the ROM can't be accessed. I'd suggest you pull both and tweak the socket pins and also spray with something like Electrolube or Deoxit before reassembly. It's really easy to upset these sockets.
This is what I meanviewtopic.php?f=17&t=1484&hilit=PLCC
Sometimes cleaning is not enough.
Users browsing this forum: ClaudeBot and 202 guests
