Here goes.......
Icky - Progress
Re: Icky - Progress
Re: Icky - Progress
:shock: pins just hanging by a thread.
With WD1772 data pins out and HDD connected it goes to desktop - thinks it is seeing 2 disks attached on TOS boot screen
Thought I would run the Hard Disk test from the DiagCart and I got this
Hard Disk DMA Exerciser
WARNING: abnormal termination may result in lost data.
Hit <Esc> key to stop program.
Q=quit, P=Park heads, S=start
Controller not responding
Re: Icky - Progress
I never used that test in the cart.. So no idea..
Hard drive I think should auto boot to desktop if setup to do so on your stfm ? Main thing is if you can get a hard drive icon up on desktop... Obviously can't boot driver from floppy...
Re: Icky - Progress
I can just see it now, rights sold to Warner brothers, Bruce Willis played Icky and Tom Cruise playing Exxos...
Re: Icky - Progress
I can just see the trailer now :)Forgottenmyname wrote: 12 Oct 2018 07:35I can just see it now, rights sold to Warner brothers, Bruce Willis played Icky and Tom Cruise playing Exxos...
Re: Icky - Progress
So HDD on an original ST drops to desktop with C drive icon.exxos wrote: 12 Oct 2018 00:11 I never used that test in the cart.. So no idea..
HDD on STF Remake with data lines out on the WD1772 drops to desktop straight. Doesn't boot from HDD.
Re: Icky - Progress
I don't suppose your STFM has the 1772 in a socket ? Wondering if you can simply remove the 1772 from a working machine and see if the HDD boots up still...Icky wrote: 12 Oct 2018 15:44 So HDD on an original ST drops to desktop with C drive icon.
Re: Icky - Progress
Now I did something similar but with the DMA. Was pondering and glanced at my STM 520 wall art and noticed the DMA was socketed.exxos wrote: 12 Oct 2018 16:07I don't suppose your STFM has the 1772 in a socket ? Wondering if you can simply remove the 1772 from a working machine and see if the HDD boots up still...Icky wrote: 12 Oct 2018 15:44 So HDD on an original ST drops to desktop with C drive icon.
I pulled it out and placed it into the STF Remake and put the WD1772 back to normal. I got drive C but there are more oddities.
Now its reversed Floppy isn't working when HDD is plugged in
Re: Icky - Progress
:lolbig:
Its like some combos of DMA and 1772 are not liked, but the "conflict" should be resolved with removing the 1772 databus :roll:
I sent you a new 1772, so you can try that in your board... It could be possible the 1772 or DMA you have might be faulty ?
Re: Icky - Progress
Thanks for 1772 - will see what that does when plugging in.exxos wrote: 12 Oct 2018 16:41:lolbig:
Place your bets now for when I plug it in - will it swap the other way, neither HDD or Floppy will work or we get success. :D
I did look for a socketed one but the only one I could see was an Ajax in my TT but I don't want to be messing with my TT.
Crazy times these past few days. Lots of discussions around the DMA / WD1772 though.
Also to note its working with Gigafile as well. Means I can retire my noisy Megafile back to storage.
What are your thoughts on the next board around this area?
