Keeping CS high disables the 1772.. so doesn't seem to be a bus conflict in this case, so I don't think a Ajax will help.
The only thing to try is the capacitors like on gigafile mod I did.
Icky - Progress
Re: Icky - Progress
Makes senseexxos wrote: 11 Oct 2018 08:51 Keeping CS high disables the 1772.. so doesn't seem to be a bus conflict in this case, so I don't think a Ajax will help.
I did start looking at this last night could only find two 68pF capacitors. Tried them but made no difference.
Re: Icky - Progress
I think it has to be around 390pF to make any odds..Icky wrote: 11 Oct 2018 11:18 I did start looking at this last night could only find two 68pF capacitors. Tried them but made no difference.
Might be better to look into the video noise issues for the time being..
Looked at the 1772 timings...
So basically 150ns data is valid after CS goes high, aka 1 clock cycle. So assuming this is why the STE had the clocked buffers to stop bus conflicts on the DMA bus..
So I will most likely add those buffers on the next board just to be on the safe side. Looks like Atari kept to that convention in a lot of later machines.
Doesn't help with Icky's issue, but obviously there is a issue with these, even though it doesn't seem to be very apparent.
Re: Icky - Progress
BTW - Did you try lifting DMA pin 24, and connect the socket end to 5V (this will disable CS to the hard drive)... In theory with no drive selected it should allow the floppy drive to still work then as can't be any bus conflicts as the HDD is prevented from being enabled...
Thinking about possible bus conflicts again.. Why didn't Atari just clock out HDCS in the first place :roll:
Re: Icky - Progress
Didn’t get that far last night. Will take a look tonight.exxos wrote: 11 Oct 2018 15:16 BTW - Did you try lifting DMA pin 24, and connect the socket end to 5V (this will disable CS to the hard drive)... In theory with no drive selected it should allow the floppy drive to still work then as can't be any bus conflicts as the HDD is prevented from being enabled...
Re video noise it seems to relate to the PSU being used. Trying different ones creates differing types of noise.
Re: Icky - Progress
Probably stray RF being picked up on the RGB drivers.. so not surprising.Icky wrote: 11 Oct 2018 17:52 Re video noise it seems to relate to the PSU being used. Trying different ones creates differing types of noise.
Re: Icky - Progress
Lifted pin 24 on DMA and tied to 5V.Icky wrote: 11 Oct 2018 17:52Didn’t get that far last night. Will take a look tonight.exxos wrote: 11 Oct 2018 15:16 BTW - Did you try lifting DMA pin 24, and connect the socket end to 5V (this will disable CS to the hard drive)... In theory with no drive selected it should allow the floppy drive to still work then as can't be any bus conflicts as the HDD is prevented from being enabled...
With HDD connected the Floppy was seen.
Re: Icky - Progress
That is interesting as doing the reverse by disabling the floppy didn't make the hard drive work..Icky wrote: 11 Oct 2018 20:47 Lifted pin 24 on DMA and tied to 5V.
Can you put the pin back, and see if you can see pin 24 & 22 both go low at the same time at any point ? Might be tricky to capture both, probably a trigger on pin 24 might be best.. TOS may only pulse the signal once after power up... or capture a second if your scope has enough memory, then you can see exactly if either signal goes low, and zoom in to see if both going low at the same time...
You could also try lifting the 1772 data pins out of the socket.. see if the HDD boots then...
EDIT2:
I still think its a bus conflict.. looking at the FDCS line is driving the flipflop, so its isolating the DMA bus for a CLK8 cycle after 1772 access....
I think isolating the 1772 from the DMA based on FDCS would do the same job (and use 2 less chips)..
But of course need to know more about what is going on first.. but clearly disabling the HDD via CS is preventing the issue, and there isn't much else common other than the databus..
Re: Icky - Progress
Yes its tricky am not currently seeing them go low at the same point - I could be missing it though.exxos wrote: 11 Oct 2018 21:18That is interesting as doing the reverse by disabling the floppy didn't make the hard drive work..Icky wrote: 11 Oct 2018 20:47 Lifted pin 24 on DMA and tied to 5V.
My WD1772 pins are starting to get a bit weak so am going to break something if I continue messing with it. Currently don't have a spare to hand. Might have to go on a raid.exxos wrote: 11 Oct 2018 21:18 EDIT:
This is perplexing - just to make sure I am not going mad have tested again the megafile with an original and it sees both floppy and hdd.exxos wrote: 11 Oct 2018 21:18 EDIT2:
Re: Icky - Progress
If you have a spare socket, you can cut the socket pins to do the same job.. I think lifting the datapins is going to be a huge clue...Icky wrote: 11 Oct 2018 23:12 My WD1772 pins are starting to get a bit weak so am going to break something if I continue messing with it. Currently don't have a spare to hand. Might have to go on a raid.
If not, break the 1772 if needs be.. I will send you a replacement one... The test needs to be done...
Good idea..Icky wrote: 11 Oct 2018 23:12 This is perplexing - just to make sure I am not going mad have tested again the megafile with an original and it sees both floppy and hdd.
Though its clear there is a conflict as Atari added the DMA bus delay based on the 1772 CS line on the STE..
As Rodolphe suggested, AJAX might not suffer, BUT, the 1772 datasheet says 150ns max.. so possible some have a lower hold time and work fine on the STFM... So some of these long term DMA issues (only on STF/M that is) could be linked to what batch of 1772 is used...
Break the pins :P
