There's the Windows way and there's everyone else's way.exxos wrote: 16 Apr 2024 15:01 All just seems way to over complicated to me. Think I am just better sticking to windows stuff .
If you're used to one, the other will seem complicated. ;)
Folder PATH listing for volume bootfs
Volume serial number is 9E81-4F92
J:.
³ bcm2708-rpi-b-plus.dtb
³ COPYING.linux
³ LICENCE.broadcom
³ issue.txt
³ cmdline.txt
³ bcm2708-rpi-b-rev1.dtb
³ bcm2708-rpi-b.dtb
³ bcm2708-rpi-cm.dtb
³ bcm2708-rpi-zero-w.dtb
³ bcm2708-rpi-zero.dtb
³ bcm2709-rpi-2-b.dtb
³ bcm2709-rpi-cm2.dtb
³ bcm2710-rpi-2-b.dtb
³ bcm2710-rpi-3-b-plus.dtb
³ bcm2710-rpi-3-b.dtb
³ bcm2710-rpi-cm3.dtb
³ bcm2710-rpi-zero-2-w.dtb
³ bcm2710-rpi-zero-2.dtb
³ bcm2711-rpi-4-b.dtb
³ bcm2711-rpi-400.dtb
³ bcm2711-rpi-cm4-io.dtb
³ bcm2711-rpi-cm4.dtb
³ bcm2711-rpi-cm4s.dtb
³ bootcode.bin
³ config.txt
³ fixup.dat
³ fixup4.dat
³ fixup4cd.dat
³ fixup4db.dat
³ fixup4x.dat
³ fixup_cd.dat
³ fixup_db.dat
³ fixup_x.dat
³ kernel.img
³ kernel7.img
³ kernel7l.img
³ kernel8.img
³ start.elf
³ start4.elf
³ start4cd.elf
³ start4db.elf
³ start4x.elf
³ start_cd.elf
³ start_db.elf
³ start_x.elf
³ cmdline-new.txt
³ tree.txt
³
ÀÄÄÄoverlays
adafruit-st7735r.dtbo
README
act-led.dtbo
adau7002-simple.dtbo
adafruit18.dtbo
adau1977-adc.dtbo
akkordion-iqdacplus.dtbo
ads1015.dtbo
ads1115.dtbo
ads7846.dtbo
adv7282m.dtbo
adv728x-m.dtbo
arducam-pivariety.dtbo
anyspi.dtbo
allo-boss-dac-pcm512x-audio.dtbo
allo-boss2-dac-audio.dtbo
allo-digione.dtbo
allo-katana-dac-audio.dtbo
allo-piano-dac-pcm512x-audio.dtbo
allo-piano-dac-plus-pcm512x-audio.dtbo
apds9960.dtbo
applepi-dac.dtbo
arducam-64mp.dtbo
audioinjector-addons.dtbo
at86rf233.dtbo
audioinjector-isolated-soundcard.dtbo
audioinjector-bare-i2s.dtbo
vc4-kms-dsi-lt070me05000-v2.dtbo
audioinjector-ultra.dtbo
audioinjector-wm8731-audio.dtbo
audiosense-pi.dtbo
audremap.dtbo
balena-fin.dtbo
camera-mux-2port.dtbo
camera-mux-4port.dtbo
cap1106.dtbo
chipdip-dac.dtbo
cirrus-wm5102.dtbo
cm-swap-i2c0.dtbo
cma.dtbo
crystalfontz-cfa050_pi_m.dtbo
cutiepi-panel.dtbo
dacberry400.dtbo
dht11.dtbo
dionaudio-kiwi.dtbo
dionaudio-loco-v2.dtbo
dionaudio-loco.dtbo
disable-bt.dtbo
disable-emmc2.dtbo
disable-wifi.dtbo
dpi18.dtbo
dpi18cpadhi.dtbo
dpi24.dtbo
draws.dtbo
dwc-otg.dtbo
dwc2.dtbo
edt-ft5406.dtbo
enc28j60-spi2.dtbo
enc28j60.dtbo
exc3000.dtbo
fbtft.dtbo
fe-pi-audio.dtbo
fsm-demo.dtbo
gc9a01.dtbo
ghost-amp.dtbo
goodix.dtbo
googlevoicehat-soundcard.dtbo
gpio-fan.dtbo
gpio-hog.dtbo
gpio-ir-tx.dtbo
gpio-ir.dtbo
gpio-key.dtbo
gpio-led.dtbo
gpio-no-bank0-irq.dtbo
gpio-no-irq.dtbo
gpio-poweroff.dtbo
gpio-shutdown.dtbo
hd44780-lcd.dtbo
hdmi-backlight-hwhack-gpio.dtbo
hifiberry-amp.dtbo
hifiberry-amp100.dtbo
hifiberry-amp3.dtbo
hifiberry-dac.dtbo
hifiberry-dacplus.dtbo
hifiberry-dacplusadc.dtbo
hifiberry-dacplusadcpro.dtbo
hifiberry-dacplusdsp.dtbo
hifiberry-dacplushd.dtbo
hifiberry-digi-pro.dtbo
hifiberry-digi.dtbo
highperi.dtbo
hy28a.dtbo
hy28b-2017.dtbo
hy28b.dtbo
i-sabre-q2m.dtbo
i2c-bcm2708.dtbo
i2c-fan.dtbo
i2c-gpio.dtbo
i2c-mux.dtbo
i2c-pwm-pca9685a.dtbo
i2c-rtc-gpio.dtbo
i2c-rtc.dtbo
i2c-sensor.dtbo
i2c0.dtbo
i2c1.dtbo
i2c3.dtbo
i2c4.dtbo
i2c5.dtbo
i2c6.dtbo
i2s-dac.dtbo
i2s-gpio28-31.dtbo
ilitek251x.dtbo
imx219.dtbo
imx258.dtbo
imx290.dtbo
imx296.dtbo
imx327.dtbo
imx378.dtbo
imx462.dtbo
imx477.dtbo
imx519.dtbo
imx708.dtbo
iqaudio-codec.dtbo
iqaudio-dac.dtbo
iqaudio-dacplus.dtbo
iqaudio-digi-wm8804-audio.dtbo
iqs550.dtbo
irs1125.dtbo
jedec-spi-nor.dtbo
justboom-both.dtbo
justboom-dac.dtbo
justboom-digi.dtbo
ltc294x.dtbo
max98357a.dtbo
maxtherm.dtbo
mbed-dac.dtbo
mcp23017.dtbo
mcp23s17.dtbo
mcp2515-can0.dtbo
mcp2515-can1.dtbo
mcp2515.dtbo
mcp251xfd.dtbo
mcp3008.dtbo
mcp3202.dtbo
mcp342x.dtbo
media-center.dtbo
merus-amp.dtbo
midi-uart0.dtbo
midi-uart1.dtbo
midi-uart2.dtbo
midi-uart3.dtbo
midi-uart4.dtbo
midi-uart5.dtbo
minipitft13.dtbo
miniuart-bt.dtbo
mipi-dbi-spi.dtbo
mlx90640.dtbo
mmc.dtbo
mpu6050.dtbo
mz61581.dtbo
ov2311.dtbo
ov5647.dtbo
ov7251.dtbo
ov9281.dtbo
overlay_map.dtb
papirus.dtbo
pca953x.dtbo
pcie-32bit-dma.dtbo
pibell.dtbo
pifacedigital.dtbo
pifi-40.dtbo
pifi-dac-hd.dtbo
pifi-dac-zero.dtbo
pifi-mini-210.dtbo
piglow.dtbo
piscreen.dtbo
piscreen2r.dtbo
pisound.dtbo
pitft22.dtbo
pitft28-capacitive.dtbo
pitft28-resistive.dtbo
pitft35-resistive.dtbo
pps-gpio.dtbo
proto-codec.dtbo
pwm-2chan.dtbo
pwm-ir-tx.dtbo
pwm.dtbo
pwm1.dtbo
qca7000-uart0.dtbo
qca7000.dtbo
ramoops-pi4.dtbo
ramoops.dtbo
rotary-encoder.dtbo
rpi-backlight.dtbo
rpi-codeczero.dtbo
rpi-dacplus.dtbo
rpi-dacpro.dtbo
rpi-digiampplus.dtbo
rpi-ft5406.dtbo
rpi-poe-plus.dtbo
rpi-poe.dtbo
rpi-sense-v2.dtbo
rpi-sense.dtbo
rpi-tv.dtbo
rra-digidac1-wm8741-audio.dtbo
sainsmart18.dtbo
sc16is750-i2c.dtbo
sc16is752-i2c.dtbo
sc16is752-spi0.dtbo
sc16is752-spi1.dtbo
sdhost.dtbo
sdio.dtbo
seeed-can-fd-hat-v1.dtbo
seeed-can-fd-hat-v2.dtbo
sh1106-spi.dtbo
si446x-spi0.dtbo
smi-dev.dtbo
smi-nand.dtbo
smi.dtbo
spi-gpio35-39.dtbo
spi-gpio40-45.dtbo
spi-rtc.dtbo
spi0-0cs.dtbo
spi0-1cs.dtbo
spi0-2cs.dtbo
spi1-1cs.dtbo
spi1-2cs.dtbo
spi1-3cs.dtbo
spi2-1cs.dtbo
spi2-2cs.dtbo
spi2-3cs.dtbo
spi3-1cs.dtbo
spi3-2cs.dtbo
spi4-1cs.dtbo
spi4-2cs.dtbo
spi5-1cs.dtbo
spi5-2cs.dtbo
spi6-1cs.dtbo
spi6-2cs.dtbo
ssd1306-spi.dtbo
ssd1306.dtbo
ssd1331-spi.dtbo
ssd1351-spi.dtbo
superaudioboard.dtbo
sx150x.dtbo
tc358743-audio.dtbo
tc358743.dtbo
tinylcd35.dtbo
tpm-slb9670.dtbo
tpm-slb9673.dtbo
uart0.dtbo
uart1.dtbo
uart2.dtbo
uart3.dtbo
uart4.dtbo
uart5.dtbo
udrc.dtbo
ugreen-dabboard.dtbo
upstream-pi4.dtbo
upstream.dtbo
vc4-fkms-v3d-pi4.dtbo
vc4-fkms-v3d.dtbo
vc4-kms-dpi-generic.dtbo
vc4-kms-dpi-hyperpixel2r.dtbo
vc4-kms-dpi-hyperpixel4.dtbo
vc4-kms-dpi-hyperpixel4sq.dtbo
vc4-kms-dpi-panel.dtbo
vc4-kms-dsi-7inch.dtbo
waveshare-can-fd-hat-mode-a.dtbo
vc4-kms-dsi-lt070me05000.dtbo
vc4-kms-kippah-7inch.dtbo
vc4-kms-v3d-pi4.dtbo
vc4-kms-v3d.dtbo
vc4-kms-vga666.dtbo
vga666.dtbo
vl805.dtbo
w1-gpio-pullup.dtbo
w1-gpio.dtbo
w5500.dtbo
watterott-display.dtbo
wm8960-soundcard.dtbo
wittypi.dtbo
waveshare-can-fd-hat-mode-b.dtbo
Yep, will have to order one.Steve wrote: 16 Apr 2024 20:10 Just goto amazon and pick up a Sandisk 32gb card next day delivery for £10..... no stress then. You do realise you could use a bigger card also? Like a 64gb? It would work too.
That was done with rufus.You should use a dedicated app designed for writing disk images, like rufus or win32diskimager or balena etcher.
Windows is only ever going to see one partition, isn't it? Only boot is FAT32.Steve wrote: 16 Apr 2024 20:10 ps - it has only written 1 partition. not the entire image to disk. You should use a dedicated app designed for writing disk images, like rufus or win32diskimager or balena etcher.
True. I've not checked in Linux.Badwolf wrote: 16 Apr 2024 21:47 Windows is only ever going to see one partition, isn't it? Only boot is FAT32.
I've not tried it as I wouldn't know unless it connects to WiFi.. but that card has @Steve settings which wont work on my network... That's another problem..Does that SD card boot on the Pi, @exxos?
Because @Steves 32GB card is 640MB larger than my 32GB card and it won't save the image.Making these Pi images is really straightforward normally. Why didn't the Pi Imaging software work?
That looks ok.
sudo mount /dev/sdg2 /mntAh, you haven't got the micro HDMI cable yet?exxos wrote: 16 Apr 2024 21:58I've not tried it as I wouldn't know unless it connects to WiFi.. but that card has @Steve settings which wont work on my network... That's another problem..Does that SD card boot on the Pi, @exxos?
I meant the normal install. I didn't understand why you abandoned that approach. Does that let you preconfigure all of this then you just log in and copy what you want from Steve's image?Because @Steves 32GB card is 640MB larger than my 32GB card and it won't save the image.Making these Pi images is really straightforward normally. Why didn't the Pi Imaging software work?
Because @Steve said there was loads to configure and he hasn't tried the latest firmware yet. His setup works on the H5. So he wanted me to have a more "plug and play" experience. Nobody AFAIK has tested the latest firmwares , so it could be broke for all we know on the H5 now.Badwolf wrote: 17 Apr 2024 10:08 I meant the normal install. I didn't understand why you abandoned that approach. Does that let you preconfigure all of this then you just log in and copy what you want from Steve's image?
Ah, yeah. Getting a PiStorm going will involve a lot of typing, I'm afraid. :(exxos wrote: 17 Apr 2024 10:18 My HDMI cable has come, but I'm not at home today and need to keep off the pc for a few days now anyway. All this Linux stuff isn't RSI friendly.. I can't type more than a couple of sentences each day before I am in a lot of pain :(
Users browsing this forum: ClaudeBot, HigashiJun, Majestic-12 [Bot], Steve and 17 guests
