TheNameOfTheGame
Post by TheNameOfTheGame »
Beautiful!
agranlund
Post by agranlund »
Quick test with Copyback enabled - unsurprisingly it makes an enormous difference!
EmuTOS is assuming Writethrough so I would need to do some work there before I can have it enabled by default, but it's cool to see where it will eventually end up.
Copyback enabled: 221
Copyback disabled: 113
nokturnal
Post by nokturnal »
@agranlund Have you enabled superscalar dispatch (ESS bit in the PCR) ?
nokturnal
www: https://nokturnal.pl
agranlund
Post by agranlund »
nokturnal wrote: 13 Apr 2024 19:10 @agranlund Have you enabled superscalar dispatch (ESS bit in the PCR) ?
Yep!
nokturnal
Post by nokturnal »
@agranlund awesome, just curious, is this done at application level, or maybe EmuTOS is doing it at startup already, when detecting 060 for instance?
nokturnal
viking272
Post by viking272 »
Incredible achievements here, looks amazing!
agranlund
Post by agranlund »
One of my favourite bit of Atari kit appears to be working, so that's the parallel port tested :)
It works when Atari is client and server runs on the Mac. But it's very unstable if I do the opposite and I'm not sure why yet.
agranlund
Post by agranlund »
After much faffing about. Finally. FreeMiNT is running!
It's really quite bizarre seeing that same desktop I use on the ST and Vampire, but running on something I've built myself.
Here was the first boot to the default stuff, before I replaced with my N.AES+Thing setup
Doom next ;)
viking272
Post by viking272 »
Bravo!
Is that a 68060 EC you're running in there? Makes sense at this stage of the development. :)
