Hehe.
:crossed1:
Stuff and Things.
Re: Stuff and Things.
Indeed :)
Not what I wanted to see on my uKenbak-1 delivery...
Oh
Higgy
@rubber_jonnie - on the PS2Slim just check it is ok with CD, DVD dual and single layer.
I've got one that won't read dual layer games. So that one was an ideal candidate for the Router and OPL games.
I can't remember now, but blue coloured discs indicate one or the other.
I'll check it once I have a video cable as that should be here tomorrow, but for the moment all I can do is see if the disk spins.Higgy wrote: 15 Mar 2024 12:35 @rubber_jonnie - on the PS2Slim just check it is ok with CD, DVD dual and single layer.
Thanks.
Woo hoo, it's moving :)rubber_jonnie wrote: 15 Mar 2024 10:30 Not what I wanted to see on my uKenbak-1 delivery...
Well the PS2 Slim is reassembled, and a controller and a PSU arrived today:
Just waiting for the AV lead which should be here late afternoon early evening.
I feel confident it'll run fine after what I've seen internally, so fingers crossed for later :)
I would recommend you look into your WiiU sooner rather than later. Nintendo are going to turn off the WiiU download/update server soon. It will be much harder to enjoy the WiiU once these are turned off and WiiU USB Helper Installer doesn't work anymore. You've got until April 8th to get a large USB HDD/SSD/Key softmod your WiiU and "download" everything you want directly from the BigN to your WiiU.
I have been playing on it here and there, it's an interesting (Or odd) console that's for sure. I thought the one I got from you was already softmodded as it came with a HDD full of games, or am I going to need to do something else now?alexh wrote: 16 Mar 2024 21:14 I would recommend you look into your WiiU sooner rather than later. Nintendo are going to turn off the WiiU download/update server soon. It will be much harder to enjoy the WiiU once these are turned off and WiiU USB Helper Installer doesn't work anymore. You've got until April 8th to get a large USB HDD/SSD/Key softmod your WiiU and "download" everything you want directly from the BigN to your WiiU.
Users browsing this forum: apple [bot], Baidu [Spider], ClaudeBot and 173 guests
