That would work only for monochrome (high res). The OSSC VGA expects 31khz input on the VGA.
Where'd you get that information from? I have no problem running 15kHz on the VGA input on my OSSC. I don't like to mess with SCART cables! :-)
See the screenshot of my Falcon030 in 15kHz/50Hz RGB mode, using a VGA cable from Falcon to OSSC, and then connected to my Eizo EV2455 using a HDMI cable. Works like a charm!
officer960 wrote: 26 Jul 2018 03:00
I ordered a couple of SVCART RGB cables for the ST(e) and Amiga from EU that should be here... eventually :)
My OSSC did mail out today though. Hopefully in a couple of weeks it should be here.
I'm convinced you'll be very satisfied. The SCART cables will work as well, but the UBE switch is awesome! :-)
Also, make sure you get the remote for the OSCC, I find it hard to navigate using the buttons on the panel.
@dhedberg you're absolutely correct. The company that sold me the OCCS told me the erroneous information about the VGA:
For 15khz sources we always recommend SCART or component. The OSSCs VGA port is really designed with 31khz sources in mind. It lacks the low pass filter that many 15khz devices need.
It works perfectly with my 1040 STFM, Mega STe and Amiga's connected to the VGA (and SCART) port.
