Falcon RGB adapter question
marbosar77
Post by marbosar77 »
Hello again guys.
Very recently I have applied the clock patch V3.0 on my vanilla Falcon, as well as the fpu overclock (40mhz). I did everything explained on exxos webpages, connected and soldered everything, but... when I turn on the computer, a message shows on monitor saying "Not optimum mode resolution", even if all the lights turn on.
If I go back to "vanilla mode", everything works again.
What could it be?
Here I attach some pictures of what I have done.
As you can see, I'm using a vga-rgb adapter, and I have yet to apply the SDMA clock line delay (could that be the reason?).
Any help would be very appreciated!
Thanks in advance.
Re: Falcon RGB adapter question
You have to setup the adapter with the software and select the resolutions to use etc. You can't just plug it in with a OSC and expect it to work. You likely have some resolution which your monitor doesn't support.
I also assume you are powering the adapter when using the OSC else you will be introducing problems with the Videl clock.
Please see the information here. viewtopic.php?f=20&t=935
Also you need a battery in your RTC else your falcon will be booting with random settings which isn't going to help. There is software to setup defaults here. viewtopic.php?f=10&t=599#p3991
Also you need to select "delay off" on the clock patch https://exxosforum.co.uk/atari/last/fal ... #V3CHANGES as you are likely causing a clock malfunction in not setting it up correctly.
I also assume you cut the track under the FPU socket before inserting the FPU OC board ?
Also please see how to correctly places images in posts. viewtopic.php?f=20&t=2357
marbosar77
@exxos many thanks, and apologies.
Post by HigashiJun »
What kind of wires did you solder to the clock patch ?
Are these copper wires ?
marbosar77
@HigashiJun of course, copper wires with envelope. Why did you ask?
marbosar77 wrote: 02 Mar 2024 09:50 @HigashiJun of course, copper wires with envelope. Why did you ask?
That's what I wanted to hear...
Everything's good if your wires are insulated.
8-)
marbosar77
HigashiJun wrote: 02 Mar 2024 10:08
8-)
:cheers:
Looks like a good job! 😃
