A Grand Day Out
Re: A Grand Day Out
I don’t think the ram is faulty either as sometimes it passed the test and others it didn’t.
That’s a good upgrade if you do feel the need to change the ram though.
Re: A Grand Day Out
PhilC wrote: 15 Feb 2024 14:38 I don’t think the ram is faulty either as sometimes it passed the test and others it didn’t.
At that price I would have ordered it today, but they are out of stock :(
It's sitting running Dead Test (I know that's for C64), but it's done 25 iterations without finding a RAM issue, so right now I don't know what Diag I can trust.
Also, Dead Test won't go beyond flashing the screen if the RAM is bad, and I get to the proper diag screen, which is another indicator that RAM, at least for the C64 side, is good.
My money is on the PLA, but the MMU is easily swapped as in a socket so I'll try that first when the parts arrive.
Re: A Grand Day Out
You did say you'd used the C128 Test earlier right?
Re: A Grand Day Out
PhilC wrote: 15 Feb 2024 15:51 You did say you'd used the C128 Test earlier right?
I did, and it fails on the PLA and RAM.
Re: A Grand Day Out
Out of curiosity, and since it is socketed, I pulled the MMU, cleaned the legs and Electrolubed the socket, but I still get the same faults.
However the diags seem to be running more reliably since doing this. Whereas before they were hanging after the first iteration, they are now running repeatedly.
They still say the PLA is bad though!
Re: A Grand Day Out
rubber_jonnie wrote: 16 Feb 2024 11:43 Out of curiosity, and since it is socketed, I pulled the MMU, cleaned the legs and Electrolubed the socket, but I still get the same faults.
That sounds like a good improvement. If I get a chance I'll run the drags through a good C128 motherboard I have and will let you know if that shows its failed as well.
Re: A Grand Day Out
PhilC wrote: 16 Feb 2024 11:56
Sounds good to me, thanks.
Re: A Grand Day Out
Boo! PLA and MMU won't be here until Monday.
I suppose I could get ahead of myself and desolder the PLA and socket it, providing of course I have the right size socket!!
Re: A Grand Day Out
rubber_jonnie wrote: 17 Feb 2024 10:16 Boo! PLA and MMU won't be here until Monday.
Use two 24 pin sockets back to back, it’s cheaper than getting 48 pin ones.
Re: A Grand Day Out
PhilC wrote: 17 Feb 2024 10:22
It wouldn't be the first time I've done that..
Users browsing this forum: apple [bot], ClaudeBot, trendiction [bot] and 14 guests
