General Stuff(tm)
Re: General Stuff(tm)
Pretty easy as they were used for a great number of machines, including the TRS80 etc. They're Tandon TM-100-2 drives.
With a little help from my friends:
Almost boots:
Almost boots:
Well, it's not the 74LS243s as I've swapped them as they were socketed.
The next thing I might do is convert the .IMD files I have for Kaypro boot disks into .HFE files and hook up a Gotek to take any potential floppy issues out of the picture. It will also allow me to test a large variety of images in case it's a ROM compatibility issue with the boot image causing the hang. It removes another variable.
Definitely worth a go.stephen_usher wrote: 09 Feb 2024 18:40 Well, it's not the 74LS243s as I've swapped them as they were socketed.
I've found a disk image which will boot to the prompt now...
But it's not reading the keyboard.
I can see fro the oscilloscope that the machine is receiving data on the keyboard interface so I will have to see where that goes and if there's a problem somewhere down the line.
The keyboard data is getting to the SIO chip.
Of course the questions now are, is it the correct data and is the SIO chip working?
It's not a foam and foil conductive pad keyboard is it? They are notorious for failing over time.stephen_usher wrote: 10 Feb 2024 12:37 The keyboard data is getting to the SIO chip.
It wouldn't be sending data to the computer if the key switches weren't working.
The keyboard is sending out ASCII values for the key presses, so that's fine.
I found an image which did a DIR listing at boot:
All good on the display side except the deflection coils could do with rotating a little bit as the image isn't horizontal.
Wrote the data to a real floppy and...
It boots faster with a real floppy vs. the Gotek strangely.
Users browsing this forum: Acsi, ClaudeBot, stephen_usher and 11 guests
