General Stuff(tm)
Re: General Stuff(tm)
The Mean Well is here, but my brain isn't as I've hardly slept for the last couple of nights.
I can relate to the no sleeping, it's been the same for me too. Hope you get some Zzzzz's soon.stephen_usher wrote: 06 Feb 2024 14:00 The Mean Well is here, but my brain isn't as I've hardly slept for the last couple of nights.
I got back early from my birthday meal so pressed on with the Kaypro power supply.
Mounted the Mean Well to the adapter plate and epoxyed the original connector to the plate as well
Then wired it all up, tested the voltages, tested again and triple checked.
Plugged it all in...
Turned on the power and...
BANG! BANG! BANG! FLASH!
Lots of explosions and sparks from the two Shugart floppy drives!
My first thought was, "Have I messed up?" Tested the voltages again and all fine. Then I realised... tantalums!!! Flippin tantalums on the 12V rail of the floppy drives. *sigh*
Disconnected the power to the drives and switched on...
Yay!!! A working Kaypro, well except for the floppies.
I'll have to find out what values they should be and fit replacements.
Yaaay.
Birthday fireworks and a booting Kaypro, what more could you ask for :)
Hehe.
Well, some Imperial allen keys would be useful, so I can get the flippin' drives out!
It wouldn't be the same without the fireworks :fire1:
The Imperial allen keys arrived via Amazon Prime so I've managed to get the floppy drives out of the Kaypro....
Soooooooo many tantalums! All 4.7uF 35V and all shorted. The explodified one is on the 5V rail surprisingly.
Oooh, that one really blew it's top! Not like it for the 5v rail though really, but hey ho, it is a tantalum :)stephen_usher wrote: 07 Feb 2024 19:01 The Imperial allen keys arrived via Amazon Prime so I've managed to get the floppy drives out of the Kaypro....
Did both drives go?
Yes, in the same way.
I've replaced them all with 10uF 16V electrolytics as they're just doing bulk capacitance.
The drives now run, though getting the motors and spindle to free up was "fun". The spindles are running at the correct speed but there are dead spots on the motors which means if they stop at a specific location the motor doesn't start and this is the same on both drives, but affects drive B more.
I *think* I've made a boot floppy using ImageDisk on my Win98 box and a 1.2MB drive but it's not booting. It sees the disk but can't read it. Now this could be due to the drive or the format or the images I have. Without a known good system I can't tell.
Users browsing this forum: ClaudeBot, OAI-Search [Bot], Qwantbot, trendiction [bot] and 21 guests
