General Stuff(tm)
Re: General Stuff(tm)
OK, so the transistor Q1 tests bad. Unfortunately the can is corroded just where the part number is so I can only just see that it ands in "2A" which isn't very useful as many transistor numbers end in this combination.
Also, the PCB of the power supply is crumby. It's unsually double sided but the vias seem to be made of cheese. Just putting the Hakko on the legs of the component long enough to melt the solder lifted the pads.
Loks like the transistor was a simple 2N2222A. I have some so I can try it.
Nope. No change. Oh well.
I'd better order a Meanwell RT-85B as a replacement.
stephen_usher wrote: Sat Feb 03, 2024 12:00 pm It needs the PSU's 12V to power the display. I could potentially lash up a luminance+sync->composite sync cable but far better to get the PSU working.
It's quite possible that it's the Zener. I'll have to see.
I've had to go into work this morning as the virtual infrastructure lost connectivity to the new storage, on which all the VMs reside. The two Dell 10Gb switches had both reverted to an older set of settings for some reason and lost the new VLAN configuration I set six months ago and definitely saved.
Sometimes I really dislike modern technology...
stephen_usher wrote: Sat Feb 03, 2024 7:40 pm Nope. No change. Oh well.
Power supplies, my other nemesis. Thank god for Meanwell.
I think I’d ditch the old PSU as well once the tracks started lifting.
PhilC wrote: Sat Feb 03, 2024 10:32 pm I think I’d ditch the old PSU as well once the tracks started lifting.
Well, it's not the tracks as much as the vias dying. As I said, it's a two layer board, which is very unusual for a power supply.
Hmm... Looks like the "power good" detection circuit in the OPD monitor's power supply is on the blink now. Need to investigate.
stephen_usher wrote: Sun Feb 04, 2024 1:57 pm Hmm... Looks like the "power good" detection circuit in the OPD monitor's power supply is on the blink now. Need to investigate.
Ahh Damn...
The joys of owning retro computers. Broken, then
Fixed, shortly followed by broken again.
