A5000 - diving in at the deep end!
Re: A5000 - diving in at the deep end!
Post by HigashiJun »
@PhilC
I've finally bought the following 10Base2 to 10BaseT converter on EvilBay:
Not because the other one would not work, but because of its price...
I got this one for around £85 (shipping fees included) while I would have to pay around £162 for the other one.
It's a second hand item, but it works the same way.
I will let you know how it performs once it is delivered.
Thanks for the update @HigashiJun , I had thought about getting a switch that had both networks built in but I already have too many of them.
PhilC wrote: 20 Jan 2024 08:50 Thanks for the update @HigashiJun , I had thought about getting a switch that had both networks built in but I already have too many of them.
Yeah, I had also thought about that but the only retro computer having a BNC connector is my A3000, so I have opted for the converter which is IMHO a simpler way to hook the Archie to the network.
HigashiJun wrote: 20 Jan 2024 05:25 @PhilC
The prices of these things is just ridiculous, I got very lucky with the 8 port switch I found with AUI and BNC for £30.
Just take note of the termination switch on it, as you'll probably need to turn it off if you're using a Tee piece and separate terminator.
rubber_jonnie wrote: 20 Jan 2024 10:51 The prices of these things is just ridiculous, I got very lucky with the 8 port switch I found with AUI and BNC for £30.
I agree...
Well, IDE just died in the A5000.
I don't know if it's the ancient Transcend 128mb solid state drive or if some corrosion I missed from the battery has come back to haunt me, but it's no longer found.
So, I've decided to just disable it, since I don't really need it and I have 4 SCSI drives under BlueSCSI and really don't need the space.
What a pain to remove the links to the old drive though...
All done now though.
*sigh*
stephen_usher wrote: 26 Jan 2024 14:23*sigh*
Indeed...
A5000's can take an additional 5th Column ROM and a good candidate for that space is an enhanced IDE driver such as ICS Wizzo 5 IDEFS (3v15)
This greatly improves the reliability of IDE devices such as Compact Flash or DOMs
I'm not saying this will fix your issue (you'd think that once a device works with ADFS... it shouldn't stop working) but worth a go.
https://stardot.org.uk/forums/viewtopic.php?t=11247
https://stardot.org.uk/forums/viewtopic.php?t=5388
alexh wrote: 26 Jan 2024 15:18 A5000's can take an additional 5th Column ROM and a good candidate for that space is an enhanced IDE driver such as ICS Wizzo 5 IDEFS (3v15)
Thanks.
TBH I suspect a trace failure, as whilst I did my best to clean the battery damage up, you can never tell what's lurking, and given I have a good SCSI set up, I don't think the IDE interface is something I want to persist with, especially if it means more trace repair.
I'll probably pull the Transcend out to see if it's that, but with 4 SCSI drives and the easy addition of more, I just don't need it. I would say that it's bloody annoying though!!!
Users browsing this forum: ClaudeBot and 45 guests
