I'm sure you'll figure it out :)HigashiJun wrote: 03 Dec 2023 10:53Yeah, me too...rubber_jonnie wrote: 03 Dec 2023 10:15 I hate it when that happens! Could it be the FDD controller IC? Which one did you use in the end?
I use the WD1772-PH, but I think there is an issue elsewhere.
Have to try something else, but it's for tomorrow if time allows.
Archie A3000 inbound
Re: Archie A3000 inbound
Thanks !
I hope so...
But I would like to focus on the A5000 tomorrow.
The A3000 is fully working and I'm just pimping it in now.
I'm looking forward to seeing the A5000 up and running fully. If you can, get a parallel port Zip drive, they are great for transferring software from Windows to RISCOS.HigashiJun wrote: 03 Dec 2023 11:52Thanks !
I hope so...
Yeah, I was thinking of getting one.rubber_jonnie wrote: 03 Dec 2023 12:59 I'm looking forward to seeing the A5000 up and running fully. If you can, get a parallel port Zip drive, they are great for transferring software from Windows to RISCOS.
Just have to check the local auction site.
Hope you can find one :)HigashiJun wrote: 04 Dec 2023 07:24Yeah, I was thinking getting one.rubber_jonnie wrote: 03 Dec 2023 12:59 I'm looking forward to seeing the A5000 up and running fully. If you can, get a parallel port Zip drive, they are great for transferring software from Windows to RISCOS.
If you have one... and your FDD connector is working... a Gotek is an "ok" method of transferring files from PC to A3000 or A3010 (something with no integrated IDE). The HxC software can created custom Acorn .ADF images with the files you want to transfer. I have never tried to use custom disk formats on Acorn but on Amiga & Atari you can make disks which are considerably bigger than the biggest FD disk
Found some IOMEGA ones for good prices, but I keep it for later.
I have a GOTEK and a HXC, but I like more the old FDD.alexh wrote: 04 Dec 2023 09:52 If you have one... and your FDD connector is working... a Gotek is an "ok" method of transferring files from PC to A3000 or A3010 (something with no integrated IDE). The HxC software can created custom Acorn .ADF images with the files you want to transfer. I have never tried to use custom disk formats on Acorn but on Amiga & Atari you can make disks which are considerably bigger than the biggest FD disk
On the other hand, I plan to fit a HXC as a second drive in my A5000.
But you've got IDE on A5000 which you can connect to one of these for fast file transfer between Windows/Linux/MacOS<->RiscOS:
https://www.ebay.co.uk/itm/374799702609
https://www.ebay.co.uk/itm/193578514272
@alexh
Sure.
I have the first one in my Atari STE, but used as internal.
I could make an opening in the FDD plastic cover of my A5000 and fit the CF IDE adapter, but I don't really like to alter the outside of my retro machines, and I try to keep them genuine as much as possible.
The inside is on the other hand another story, and all kind of expansions and mods are allowed.
Sure.
Users browsing this forum: apple [bot], ClaudeBot, prog99, rmahlert and 13 guests
