ACORN A5000 inbound
Re: ACORN A5000 inbound
Post by HigashiJun »
rubber_jonnie wrote: 03 Dec 2023 10:11
:yay2: :dualthumbup: :cheer:
Haven't seen one of those shapes, I think it is a later one isn't it? Mine are both very wedgy.
Yes, it's the "M-PG15" from Logitech.
https://chrisacorns.computinghistory.or ... Type3.html
My A3000 has the wedgy mouse (M-PF7):
https://chrisacorns.computinghistory.or ... Type2.html
HigashiJun wrote: 03 Dec 2023 10:50
The one I'm using for my A5000 is an M-PF7, I still need to sort out a ball for my other mouse.
@rubber_jonnie
I think that's the hardest part...
Either you manage to find one or try to make it by yourself, like you did.
I have never seen mouse balls for sale on auction sites, and particularly Acorn ones.
HigashiJun wrote: 03 Dec 2023 11:43 @rubber_jonnie
What's annoying is that I have a ton of old mice, but it uses a ball size that I just can't match. Still have plans to try and make one if I can, but not in a hurry as I have a spare.
chronicthehedgehog
Post by chronicthehedgehog »
That looks quite a comfortable well-designed mouse. Unlike others I could mention :D
Reminds me that I need to try/find another adapter for my ST. The one I have creeps like crazy
I wonder if you can make a good enough ball using a 3D printer.
stephen_usher wrote: 03 Dec 2023 13:39 I wonder if you can make a good enough ball using a 3D printer.
Probably not on my 3d printer....
I guess that the problem would be the same as the resin one I made in that the weight isn't there.
I have considered adding solder balls to the resin to add weight but not tried it yet. I also wonder if it would work coating a steel ball with rtv silicone.
How? I don't know.
What I find odd is that the original ball was clearly resin of some sort, and the remains were very light.
rubber_jonnie wrote: 03 Dec 2023 12:57 What's annoying is that I have a ton of old mice, but it uses a ball size that I just can't match. Still have plans to try and make one if I can, but not in a hurry as I have a spare.
Maybe you have already tried, but it's worth looking at Logitech mice from that period.
Last (?) repair done...
That one was quite tough, but it spared me from de-soldering the whole connector.
I just hope there are no other broken traces under it.
HigashiJun wrote: 04 Dec 2023 07:16
I have an M-PF7 from Logitech which I use with the A5000 and the ball is too big for the Acorn mouse, and I've tried a number of period mice. from generic types to branded, including period Apple mice, and all are too big.
The Acorn mouse is oddly made in Switzerland, so I call it the 'Swiss Cheese' mouse as it is a wedge shape :)
Users browsing this forum: apple [bot], ClaudeBot, nicknm, Perplexity [Bot] and 15 guests
