Thank yo sir.PhilC wrote: 30 Nov 2023 16:26 @rubber_jonnie well good luck hunting down the cap, I’ll still look for that PSU just in case.
Whoops I did it again - Sega Saturn inbound
Re: Whoops I did it again - Sega Saturn inbound
@rubber_jonnie sorry doesn’t look like I have the psu any more, probably binned it when decluttering.
No worries, I'll have a look at mine, see if I can bring it back to life.PhilC wrote: 01 Dec 2023 13:11 @rubber_jonnie sorry doesn’t look like I have the psu any more, probably binned it when decluttering.
Thanks for looking.
It’s worth looking at the new low voltage PSUs you can get for them, mine has run great since I replaced it.
Do you have any links at all?PhilC wrote: 01 Dec 2023 14:45 It’s worth looking at the new low voltage PSUs you can get for them, mine has run great since I replaced it.
Thanks.
Should be easy to build one on some veroboard. Just needs a jack plug for 12V in and a buck converter to generate the 5V (I think you can get for for a fiver on Amazon) and wire up the output plug.
On eBay it’s Sega Saturn PSU replacement but I’m sure mine was cheaper than that and I used my own 12v psurubber_jonnie wrote: 01 Dec 2023 15:15Do you have any links at all?PhilC wrote: 01 Dec 2023 14:45 It’s worth looking at the new low voltage PSUs you can get for them, mine has run great since I replaced it.
Thanks.
Very true. I have also seen Pico PSU's used too, so that may be an option.stephen_usher wrote: 01 Dec 2023 15:22 Should be easy to build one on some veroboard. Just needs a jack plug for 12V in and a buck converter to generate the 5V (I think you can get for for a fiver on Amazon) and wire up the output plug.
Thanks.PhilC wrote: 01 Dec 2023 15:25On eBay it’s Sega Saturn PSU replacement but I’m sure mine was cheaper than that and I used my own 12v psu
New PSU is ordered for the Saturn, fingers crossed it'll do the trick.
Users browsing this forum: ClaudeBot, trendiction [bot] and 12 guests
