I have a hard time removing 44 pins PLCC chips, like those used for Exxos boards, especially from the Eprom Burner socket.
I have one of those generic PLCC extractors and it works fine with larger chips. No problem with chips like GLUE or MMU. But when trying to use it with the smaller chips, it feels like it is going to break the chip and/or the socket. At least it is like that with the Eprom Burner socket. Don't know if it's a tighter socket or what.
Is it worth to invest in one of those more expensive extractors that are specific for 44-pin chips? Like this:
Or otherwise what is the recommended method.
How to remove small PLCC chips from sockets
ijor
http://pasti.fxatari.com
Re: How to remove small PLCC chips from sockets
Good question. I've never been able to get those cheap extractors to remove any cheap. The metal is to soft and the hooks are not large enough. I tend to use them to lever the chip out side by side which isn't great and risks damaging the socket.
I've never found anything better. So I wonder where you found the one in your image ? It can't be any worse than the cheap extractors..
My experience with the cheap PLCC extractors is that after relatively little use, the corners of the extractors round off due to being made of material that's too soft, and then they just stop working, and whilst you can file them to get the correct hook shape back, it's never the same. After that, it's time for the bin.
A decent puller like you've described would be quite useful.
ijor
Hakko PLCC extractor tools: https://www.digikey.com/en/products/det ... 68/9597288exxos wrote: 16 Oct 2023 09:28 I've never found anything better. So I wonder where you found the one in your image ? It can't be any worse than the cheap extractors..
Thanks.
Just saw this , though confused how its supposed to be used :shrug:
https://kaisertech.co.uk/extractor-68-p ... UXzIC7VQkE
Seems somewhat contradictory :shrug:
elterwater
ijor
Bought the small Hakko extractor and it works really great. A world of difference with the cheap universal extractors.
Thanks for letting us know. I'll have to get one of those at some point. Those cheap extractors are total garbage and always have been.ijor wrote: 17 Nov 2023 20:43 Bought the small Hakko extractor and it works really great. A world of difference with the cheap universal extractors.
