A5000 - diving in at the deep end!
Re: A5000 - diving in at the deep end!
stephen_usher wrote: 20 Oct 2023 13:58 What's your routing table like? If no route then no ping.
It shouldn't really need a routing table to ping something on the same subnet, like another PC or the gateway, which is in the settings, but I can't even ping anything local. That's not 100% true, I can ping the localhost address and the local IP address.
Well, unless the A5000 TCP/IP stack is weird and I'm missing something. Or it doesn't like my 10/100 switch.
Post by HigashiJun »
Ok, slow but good progress !
rubber_jonnie wrote: 20 Oct 2023 14:07
Even the local physical interface needs a route to the subnet it's connected to, e.g.
% netstat -r
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
default         router          0.0.0.0         UG        0 0          0 eth0
163.1.22.0      0.0.0.0         255.255.255.0   U         0 0          0 eth0
link-local      0.0.0.0         255.255.0.0     U         0 0          0 eth0
In this case the "local" network is 163.1.22.0. There's also a default route out to the router.
stephen_usher wrote: 20 Oct 2023 15:19
% netstat -r
I'll check it out, I'm used to every OS I've ever used building a routing table so that may be catching me out
Yeah, usually the route is added automatically.
Ok, so managed to get this:
Supposedly fully working for £16, so with the cabling coming from Cricklewood electronics for about the same, I should be able to set up a test BNC network and hopefully, plus since it has AUI, I can hopefully test all the elements of the A5000 NIC to see if they are all working.
Fun and games this A5000 when it comes to networking.
:dualthumbup:
Fingers crossed !
:crossed1:
Also heard back from CJE, who have been very helpful, and I'm going to try a blank system with uniboot and drivers supplied by them, see if I get any further.
Will be dead easy to set up now I have BlueSCSI installed, I can just drop in a spare SD card and blank image, so it'll make things clean and easy.
Fingers crossed I'll have this sorted soon.
So I tried running the e1info command as suggested by CJE and I can see when executing multiple times that the RX & TX frame counters are incrementing, as is the unwanted frames counter.
So I'm positive something is working and it's just a matter of time :)
Users browsing this forum: ClaudeBot, jmorden, MasterOfGizmo, petal [bot], Steve, trendiction [bot] and 17 guests
