You definitely should !rubber_jonnie wrote: 19 Sep 2023 15:10 I 'might' come over to Japan in 2025, not 100% sure as yet, but my Karate club do a trip to Okinawa annually and I might go.
A full Spectrum of emotions
Re: A full Spectrum of emotions
Bit of planning to do first :)HigashiJun wrote: 19 Sep 2023 21:52You definitely should !rubber_jonnie wrote: 19 Sep 2023 15:10 I 'might' come over to Japan in 2025, not 100% sure as yet, but my Karate club do a trip to Okinawa annually and I might go.
Well, that was a narrow squeak!!
I stole the missing transistor for the + from the spares board, figured out the pinout using my component tester and installed in the board.
Since the 12v side of the power is all I need now the RAM has been replaced, I had the multimeter ready to check the voltage as soon as I plugged the power in.
Well I got a shock, suddenly the circuit is delivering 29v!!!
Luckily I was on the ball and unplugged immediately, so no harm done, but more than a little confused that the 12v circuit was suddenly delivering more than twice the voltage it's supposed to be. Ho hum.
I bloody hate power supply circuits at times :(
At least no harm done because I was quick off the mark pulling the power.
Is there a circuit for it ?
@rubber_jonnie
29 volts !!! You were really lucky not to fry your machine...
Only one chip would be on the +12V rail with all the RAM replaced with hacked 4164 chips, the LMxxxx video encoder.HigashiJun wrote: 20 Sep 2023 10:22 @rubber_jonnie
Luckily the LM1889 survived, and I have spares at least.stephen_usher wrote: 20 Sep 2023 12:01Only one chip would be on the +12V rail with all the RAM replaced with hacked 4164 chips, the LMxxxx video encoder.HigashiJun wrote: 20 Sep 2023 10:22 @rubber_jonnie
Here you go...
TR4 isn't marked, but it's the lower of the two transistors.
If the coil is faulty and the output side is partly shorted then I guess the ratio between the two coils would be different causing the voltage to change.
Those coils are well known to fail.
What issue is that Stephen? Mine is closer to the issue 5 (I can't find a 4s specific schematic) IIRC I did check for shorts in the coil but I can do so again. It's a fairly rudimentary device that's for sure.stephen_usher wrote: 20 Sep 2023 15:06Here you go...
Users browsing this forum: ClaudeBot and 13 guests
