TT030 Reset Issue
MacTech05
Re: TT030 Reset Issue
Post by MacTech05 »
Hello Everyone,
I forgot to distinguish between the 2 photos of my TT030 Motherboard.
Photo 1 (My TT030 Motherboard 2.jpg) is of the metal cover that sits on the little PCB.
Photo 2 (My TT030 Motherboard.jpg) is of the small PCB in question, that wobbled when I touched it.
Thank you!
Randy
You know you can edit your posts for a few hours by clicking the pencil bottom ? It's a saves having to do multiple posts and corrections because it then gets confusing.. You can also delete your posts for a few hours by clicking the X button if you need to.
MacTech05
Post by MacTech05 »
exxos,
I apologize, I did not know that. I will make use of that option in the future.
Thank you.
Randy
On mine that PCB does have ground points on the bottom edges which are soldered to the grounds on the bottom of the motherboard. It's not really important since you don't have a VME card plugged in.
MacTech05
Post by MacTech05 »
Steve,
Sounds like I should resolder those ground points on the bottom of the motherboard, in the event I do have an occasion to install a VME Card, correct? Will soldering those ground points make the PCD more steady and not wobble? I mean on my TT motherboard it does not look as if it was soldered, just stuck through the slots on the motherboard.
Thank you.
Randy
MacTech05
Post by MacTech05 »
exxos,
Am I able to delete my posts if I edit the original post?
Thank you.
Randy
MacTech05 wrote: 14 Sep 2023 11:42 Am I able to delete my posts if I edit the original post?
X deletes your post forever.
The pencil lets you edit your post.
You don't "edit" posts to delete them. You do one or the other.
MacTech05
Post by MacTech05 »
exxos,
Got it. I edited the original to correct my mistake. I just wanted to delete the second post I submitted to correct the first one, which I have edited, so that it is correct. Since the second post is not redundant, I wanted to remove it.
Where would I find the "X" ? I have the Pencil, Exclamation Point, and Quote buttons in the top right corner of my posted messages.
Thank you.
Randy
You can solder the ground points if you want, it won't do any harm. I soldered mine. But it's probably perfectly stable when the VME bracket is connected, so in the end it probably doesn't really matter.
MacTech05 wrote: 14 Sep 2023 11:52 Where would I find the "X" ? I have the Pencil, Exclamation Point, and Quote buttons in the top right corner of my posted messages.
ah sorry users can't delete posts it seems, I thought they could for a set time. I will work on this later. But just report the posts you want to delete and and put "please delete" for the reason and a moderator will sort it for you.
