Which Jumper To Connect Clock Battery.
MacTech05
Post by MacTech05 »
When I received my TT030 last month, I discovered it does not have a clock battery installed. The velcro strip to mount it to is still stuck to the inside of the case. I want install a battery, but I am not certain which jumper the battery wire will plug into.
Could someone point me in the right direction? Is it J400?
Thank you.
Randy
Re: Which Jumper To Connect Clock Battery.
Yes, it's J400. I've forgotten whether the key is on the ground or positive side though. I think it's the same as old PC motherboards.
DoG
Post by DoG »
1 = +
2 = not connected
3 = ground
4 = ground
MacTech05
Post by MacTech05 »
I thought it was J400. I appreciate you guys confirming it.
Thank you !
Randy
