Icky - Progress
Re: Icky - Progress
Icky wrote: 23 Sep 2018 14:06 It must be quite frustrating seeing the progress and not having your hands on one. I guess you have to apply all the fixes once you get it.
Yeah :( I mean I could have tried the diagrom already if I had my board.. not easy to "debug remotely" .. Saying that you guys have made huge progress and we got a lot sorted over this past week. Hopefully this issue will be the last and we can start getting on with running GB6 and soak testing etc.
Re: Icky - Progress
exxos wrote: 23 Sep 2018 13:17 If you can hook up serial, then might be worth seeing if that works with the diagnostic cart.. worth a try I guess... No saying it will be much use, but at least it will test the rs232..
Hooked up my STF to seial using an FTDI adaptor and I am getting an out put but its' nothing meaningful.
Am I Correct its 8 N 1 and 9600?
Re: Icky - Progress
Forgottenmyname wrote: 23 Sep 2018 16:21 Hooked up my STF to seial using an FTDI adaptor and I am getting an out put but its' nothing meaningful.
I think so yes.. The garbage output could just be what the cart is sending out.
PaulJ
Re: Icky - Progress
Post by PaulJ »
Icky, look at the serial on the scope and see if the bit width is 9600 baud,
Re: Icky - Progress
Got there in the end - gone are the days when I had loads of serial cables lying around.
We have some more messages via serial so we know that the serial port works on the STF
So what we get is a message before the E7 one:
I6 Testing Bus Error handling
No (I6) error
E7 Spurious Interrupt
Re: Icky - Progress
exxos wrote: 23 Sep 2018 16:27
These are the settings on my terminal - 9600 8-N-1 / CTS / DTR
rpineau
Re: Icky - Progress
Post by rpineau »
so I6 (IPL 6) is the MFP. "No (I6) error" ..looks like MFP interrupt handler are ok.
Re: Icky - Progress
And looks like my serial is not working, lol.
Re: Icky - Progress
Forgottenmyname wrote: 23 Sep 2018 19:17 And looks like my serial is not working, lol.
It took me a couple of attempts to get the cable sorted out from STF 25 pin to my USB Serial 25 pin cable.
Re: Icky - Progress
Please could you show me the pinout you used?
It might be incompatible with my FTDI guess, so can try a usb-serial later on.
Return to “ALPHA USER BUILDS”
Users browsing this forum: ClaudeBot and 83 guests
