Yep. Pretty much about to throw in the towel with it all. I must have wasted 100+ hours on this by now. I just see it all as unpaid work which I didn't want to do in the first place. There is just no way to diagnose what is going on with anything. It's just another screwy fault in a long line of screwing faults with these original machines.Steve wrote: Mon Aug 21, 2023 8:24 pm @exxos I hope this advice is helpful, or not completely redundant - but I think you've suffered enough when it comes to STe, ACSI, DMA etc over the years. It's just gonna drag you down and make you frustrated! Perhaps you could put this to bed and then you'll have the energy to work on more fun projects for yourself![]()
Mostly I started this because the STE booster aggravates this new problem. I didn't want to end up with people having issues and not having a solution. Though not using the blitter, or using TOS162 seems to be the only solution. Though its unverified as there's only one other person who has this problem, and doesn't have the booster AFAIK anyway. I may try a different STE tomorrow, see if it happens on a different machine. Also try a integrated blitter machine as maybe Atari ditched the external blitter for more than just "cost saving" measures. Who knows.
I need to get back to the H5 stuff. As I can use TOS206 on the H5, it be interesting to do my tests to see if the H5 suffers from the same problem. Though i'd assume not. But if it does, then it could well be a bug in TOS206.
