Atari ST first model : Q11, R140 and R141 ?
The place to ask all those likely daft questions!
sporniket
Post by sporniket »
Hello,
I am almost done placing the components on the reconstruction of the Atari ST board, and the motherboard I own does not provision a place for those 3 components.
I have a clue that they should be above U41 (in the "shifter cage"), as the scanned pcb in the field manual has some traces there. I guess they are on the later revision of the board.
If someone happens to have a PCB with those components (STM) or just on the silk-screen (without modulator), I would appreciate a picture of this part.
Otherwise, I will try as best as I can to infer their positions and orientation.
Thanks in advance.
Re: Atari ST first model : Q11, R140 and R141 ?
Have you looked at the MBs here ? viewforum.php?f=53 a lot you can see the numbers of stuff on anyway.
sporniket
Post by sporniket »
I thought that I had, but on second visit, I can find some with Q11... thanks...
sporniket
Post by sporniket »
So in the end, up to rev E (e.g. viewtopic.php?f=53&t=504) the layout is the same as mine (rev. C), no Q11.
Rev. H (e.g. viewtopic.php?f=53&t=1303) and Rev. I (e.g. viewtopic.php?f=53&t=2004) have Q11, but this part of the circuit has been heavily reworked anyway, meaning a handful of components numbers does not match my schematic and the original schematic :cry: . So I just followed traces and placed components as best as I could.
I am curious to see this part on a rev. F and G.
Anyway, the placement is done, and I will rework the traces that do not match when there will be discrepancies.
Return to “NOOB QUESTIONS”
