Icky - Progress
Re: Icky - Progress
Actual sockets marked up with pin 4 mono detect
Re: Icky - Progress
Yeah just checked a socket myself and its as you expect, top row is back row of pins on pcb.
(just checking my board with a usb microscope i've just bought, found some dodgy socket pins but Rom was ok surprisingly)
Re: Icky - Progress
Icky wrote: 20 Sep 2018 22:07 Actual sockets marked up with pin 4 mono detect
Yeah, what I labeled on the PCB was actually right, but in the lib editor the pinout wasn't... see my previous post...
https://www.exxosforum.co.uk/forum/viewt ... =70#p10264
Re: Icky - Progress
exxos wrote: 20 Sep 2018 22:10
Ah - yes.
We are posting so fast missed that one. Looking at the board its going to be quite a mess to patch. I have thought of desoldering the socket and using patch wires but the that means the socket is hanging in mid air.
So I am going to patch my cable and label it only for the STF Remake board so I don't plug it into an original.
Re: Icky - Progress
Icky wrote: 20 Sep 2018 22:13 Ah - yes.
Yeah cable patch is good for now..
Leave it with me, I will design a "un-fek board" to patch it.
Re: Icky - Progress
Can you verify this is correct ? I assume what I have on the PCB is...
Re: Icky - Progress
exxos wrote: 20 Sep 2018 22:24 Can you verify this is correct ? I assume what I have on the PCB is...
Let me give you a diagram of what the pinout on the board should be - I have drawn one already.
Re: Icky - Progress
Icky wrote: 20 Sep 2018 22:31 Let me give you a diagram of what the pinout on the board should be - I have drawn one already.
OK..
This should be correct pinout (on right)
Re: Icky - Progress
OK. This is what I have been using to help me decipher. Its based on me looking down onto the board and how you have your layout pics.
I am still building the cable to this
Re: Icky - Progress
Cool, well done guys.
A productive evening with fault finding.
Keep up the good work.
Return to “ALPHA USER BUILDS”
