The Cosmic Puppet's Universe.
Re: The Cosmic Puppet's Universe.
Click upon the "gear" under one of the "meter bars" in the audio mixer and select "Advanced Properties". Look for the column called "sync". You can add a delay to the audio channel you are recording in milliseconds.
- Cosmic Puppet
Yeah, "Sync Offset"? I think this is probably how I got a weird delay when I was messing about (ended up scrapping everything and reinstalling)stephen_usher wrote: Sun Jul 02, 2023 7:24 pm Click upon the "gear" under one of the "meter bars" in the audio mixer and select "Advanced Properties". Look for the column called "sync". You can add a delay to the audio channel you are recording in milliseconds.
Thanks for this. I'll start experimenting...
- Cosmic Puppet
It doesn't have any effect. I must still be doing something wrong. Pretty frustrating.
Getting it just right is very difficult. You really need something where there's a percussion with a visual cue.
The offset on cheap encoders can be 500ms or more. My one was around 750ms.
It can help it you can see the video and audio as a waveform to see if you can measure the offset.
- Cosmic Puppet
Mine's the: StarTech.com HDMI Video Capture Device - 1080p - 60fps Capture Card - USB Video Recorder - with HDMI DVI VGA (USB3HDCAP)stephen_usher wrote: Sun Jul 02, 2023 8:17 pm Getting it just right is very difficult. You really need something where there's a percussion with a visual cue.
Now £43.00 more expensive.
I've put a delay of 10000ms in and can't see much of a difference, so obviously something is up. It's all above me.
Are you sure that you're delaying the correct channel? A 10000ms delay is 10 seconds!Cosmic Puppet wrote: Sun Jul 02, 2023 8:36 pmMine's the: StarTech.com HDMI Video Capture Device - 1080p - 60fps Capture Card - USB Video Recorder - with HDMI DVI VGA (USB3HDCAP)stephen_usher wrote: Sun Jul 02, 2023 8:17 pm Getting it just right is very difficult. You really need something where there's a percussion with a visual cue.
- Cosmic Puppet
Ha lol I just had a break and thought I should apply the delay to all audio channels to test that...
- Cosmic Puppet
Figured it out. I have to record and play back to see the change. I can't see it in real time. I'm so weighed down by these 1st world problems.
*Note* Webcam audio has to be offset by the same amount to avoid a slap delay when open at the same time.
It's working! 50 ms is looking pretty close!
- Cosmic Puppet
Amiga/Atari Wizzard Developments Mouse.
I have one of these mice and just discovered that the middle button was programmable in workbench. Does anybody know if it was possible to program this on the Atari platform using software, or was this Amiga only?
- Cosmic Puppet
OSSC Timings
Does anyone know the best settings for Low Resolution Atari with the OSSC? Can't seem to find them. Have the High Res sorted. I also remember having 5x doubling in the past but didn't write it all down so have no idea on how I did it.
