Icky - Progress
Re: Icky - Progress
Icky wrote: Thu Sep 20, 2018 9:20 pm So looking at pin 12 on the monitor socket which should be VSYNC is going to the MONO_DETECT.
I have the feeling the socket is wired wrong.
hmmm, could be.. can you check on a real ST ?
Re: Icky - Progress
exxos wrote: Thu Sep 20, 2018 9:23 pm hmmm, could be.. can you check on a real ST ?
Will do and I am going to create a patched start cable to swap those pins around to see if it works
Re: Icky - Progress
It looks right, but I guess the numbering could still be wrong somewhere...
Re: Icky - Progress
Icky wrote: Thu Sep 20, 2018 9:24 pm Will do and I am going to create a patched start cable to swap those pins around to see if it works
If one pins is wrong somehow, then others likely will be as well..
Re: Icky - Progress
Yep just checked original ST and its the other way round for those two pins. They need to be swapped. I am going to check the other pins.
Will do a patch and send you the photos.
Re: Icky - Progress
This may explain my yellow screen, as the same cable works fine on both my Megas.
Re: Icky - Progress
Icky wrote: Thu Sep 20, 2018 9:29 pm Yep just checked original ST and its the other way round for those two pins. They need to be swapped. I am going to check the other pins.
ah crap... well booo me, but yay as seems we are about to solve another problem.. question is, what went wrong with my pin numbering :roll:
Re: Icky - Progress
And can open up another line in the Exxos store.... Custom made STF monitor cables.
Icky, if you get a chance, can you please post a schematic for your working cable.
It might also be why my Ubeswitch doesn't work I guess?
Re: Icky - Progress
Forgottenmyname wrote: Thu Sep 20, 2018 9:34 pm And can open up another line in the Exxos store.... Custom made STF monitor cables.
I was just thinking that! :lol: :lol: :roll:
Re: Icky - Progress
Return to “ALPHA USER BUILDS”
