Forgottenmyname - Progress
troed
Re: Forgottenmyname - Progress
Post by troed »
Bus error loop?
Channel one yellow is /AS blue is /DTACK
It is looping as Troed says, the Newb in me hasn't worked out why yet but once we have, I think we'll be right onto the bombs step again.
P.s. not learnt how to do screen captures on my scope yet.
Can you try /AS and the ROM OE signal ?
exxos wrote: 20 Sep 2018 18:14 Can you try /AS and the ROM OE signal ?
/OE stays at 5V the whole time
Forgottenmyname wrote: 20 Sep 2018 18:18 /OE stays at 5V the whole time
To confirm you are on pin 22 ? (pin 8 of LS11) ?
exxos wrote: 20 Sep 2018 18:21
yes pin 22
Forgottenmyname wrote: 20 Sep 2018 18:22 yes pin 22
What do you get on LS11 pins 9,10,11 ?
exxos wrote: 20 Sep 2018 18:24
9 3.2 - 4v
10 same
11 same all constantly high
Forgottenmyname wrote: 20 Sep 2018 18:26 9 3.2 - 4v
10 same
4V does seem a bit low oddly, should be near 5V really... what do you get on the power pins of LS11 ?
My PSU needed a quick tweak, was running at 4.93 between 7 and 14 of the LS11 which was the same value on the floppy power connector
Return to “ALPHA USER BUILDS”
