So this is 22R and 100R clocks.
- 22R.JPG (93.33 KiB) Viewed 1189 times
- 100R.JPG (96.02 KiB) Viewed 1189 times
It does seem more stable and the keyboard repeat does seem to work a lot more stable. However it locked up halfway through a GB6 run.
It does seem more stable with the scope on it still even on X10
But I do not think it is that simple, because looks like increasing the resistor had the same effect of adding the buffer in that ST RAM speed has now dropped I think.
The first few tests shows slower speeds.
- IMG_0721.JPG (111.14 KiB) Viewed 1189 times
RAM test alone locks up
- IMG_0722.JPG (54.6 KiB) Viewed 1189 times
Ironically the RAM test does seem to complete but it fails as above when trying to redraw the main window
I don't really understand this because RAM test should be the simplest thing because the CPU would be running at 16MHz. So I suspect something is tripping up somewhere relating to ST RAM access
@Badwolf ?
