Raspberry PI PICO ATARI ST Hard Drive Emulator (WIP)
DaveC
Post by DaveC »
I got number 0004!
While using an STe, unfortunately when I try to write anything to the disk I get this error. GEMBench, Frontbench will all happily load at least.
H5 with tf536 doesn't seem to want to work with it...
DaveC wrote: Fri Jun 16, 2023 12:00 pm While using an STe, unfortunately when I try to write anything to the disk I get this error. GEMBench, Frontbench will all happily load at least.
Can you post an image of your motherboard.
DaveC wrote: Fri Jun 16, 2023 12:00 pm H5 with tf536 doesn't seem to want to work with it...
IIRC the TF536 only works with IDE ?, it's basically a unsupported branch.
I didn't have any issues with the H5, have you tried without the TF536 ?
@exxos I can confirm ACSI will not work with a TF536, same for Ultra satan etc
PhilC wrote: Fri Jun 16, 2023 12:35 pm @exxos I can confirm ACSI will not work with a TF536, same for Ultra satan etc
Thanks.
DaveC
Post by DaveC »
Weird because my icd adscsi board and a piscsi worked fine with my tf536.
Anyway my motherboard is the same as this one viewtopic.php?p=17653#p17653
(My phone is now complaining I need to charge it before it'll take a photo)
DaveC wrote: Fri Jun 16, 2023 12:58 pm Anyway my motherboard is the same as this one viewtopic.php?p=17653#p17653
It's more to see exactly what chips you have in your board like the what CPU etc. So a stock image does not really help. If you have not got the HC CPU then you're going to have the classic DMA problems anyway.
DaveC
Post by DaveC »
It doesn't have a bad dma, I have another board that does. I can still test with an HC CPU.
DaveC wrote: Fri Jun 16, 2023 1:10 pm It doesn't have a bad dma, I have another board that does. I can still test with an HC CPU.
I haven't specifically tested the "good DMA" yet. Did not really expect many people to even have one. So you may be better trying a -38 with a HC CPU initially.
Oh wow. That's what I'm seeing with my independently-built one on my STE.
I've never had DMA issues before, but haven't done the DMA pull-ups and I think I've an original CPU in there. I assumed it was my shoddy handiwork, but thse look to be the same symptoms so perhaps I need to get the STFM working to test there too.
I will bring back one of the production drives sunday and do more testing to make sure nothing has changed since the previous revision. The board I was working on I could copy files backwards and forwards all day without any problems.
